Powder coat
they are fine to do small items with, but if you do anything larger than a valve cover you may have problems. the voltage output on those are alot less than the commercial type guns. i have used the one that eastwood sells, it worked good for what it is. i still got it set-up in the back room of our shop to caot bolt heads and such, but use our larger guns to coat everything else. the craftsman gun, it is very small and has a built in compressor, if something goes wrong with that one i don't know how you would fix it, unlike the higher end systems that you can get all the replacement parts you need
steve
steve
mike1202002
13
03-20-2016 12:49 PM
Moe Craig
22
11-15-2011 08:51 PM
