dual twin turbo???
It's quite possible, but so is driving a car with your feet...that doesn't mean either of them are the best way to do it . I would recommend picking up a book such as Corky Bell's Maximum Boost, This contains information on all the math and such needed to calulate things such as turbo sizing, flow, volume, and guestimate if the power will be in a useful range.
I presume you were thinking two small turbos to fire off idle, and two larger turbos for the top end. If it's truly what you want to consider, research is your best chance of success.
it would actually be a twin sequential turbo setup. The only thing about them is they are very complex and hard to get setup correctly. Thats why a lot of people who modify imports that have a sequential turbo setup usually ditch it in favor of one larger turbo when they are trying to make a lot of power. Also with all the advances in turbo technology it is quite possible to have a turbo that spools quickly and still makes a lot of power at the top end.
thanks for that info and what i am looking to get is max boost right on take off or as close as possible. and still be able to spin the motor to between 4500 and 5k. i bought the truck which is an 85 350 crewcab dually with the intent of using it as a daily driver but with gas prices about to hit 4 dollars or so its very stupid to drive it back and forth to work and spend 20 dollars a day. so now it will become a hauling and toy truck. i dont care if it takes me 100$ to get my boat in the water just not to get me back and forth to work kinda defeats the purpose of goin.
I don't think the design you were intending is a "dual sequential turbo setup", I think you simply mean to have 4 turbos.
I would definately recommend that book again, if you haven't had time to check it out. It will walk you through everything you should know, and show you how to determine, based on your needs, what type of forced air system you will want to run.
i did read a little o fit the book store i went to was way over priced so i am waiting on it to come now so i can get all the details of exactly what i want i know the basics of it just need all the details now im basicaly wanting 4 turbos yes two to spin almost instantly then valves to cut flow to them and open more to the bigger two to feed top end the same as in a twin turbo rx7 or supra where they only use two i will be using 4 i know this isnt the most pratical setup or easy for that matter it will be something ive never seen and thats what i want something that i can say i did it myself and prob the first to do from what ive been able to find
Well I can't really comment on setting them up, as I have spent most of my time ripping them off RX7's... (in aid of a large single turbo)
Yes, they work really well for stopping turbo lag from a manufacturers point of view.
Is the system essential?
No. There are other ways to get around turbo lag, through engine tuning, correct turbo sizing etc.
To be completly honest, I think you may be attempting something that may be rediculously hard (especially if its your first turbo project).
Fitting 4 turbo's (and intercoolers, and piping) under a bonnet won't be easy, not to mention I still don't think the potential gains are as good for an aftermarket system as they are for an OEM application (purely due to the fact you can be a bit more creative with the locations of critical components, and with tuning)
bigf350 i dont want to use the turbos from an rx7 just the idea im not sure if you understood that i was using it to explain cause i dont think everyone does. as far as room for piping i have plenty. but all plans are subject to change as i am still in research. and i understand that this is prob really stupid for my first turbo prodject from scratch but it is not the first tim eive delt with turbos. i understand the basics its just all the little details that im in need of figuring out. but thank you very much for your imput im just not looking for the easiest thats no fun if you ask me
thanks
tony
thanks
tony
well guys after much consideration ive come to the conclusion that 4 turbos is very complicated but doable. with that being said thats what im going to do. althou its going to take longer then anticipated. being poor means that i have to use mostly junk yard parts and rebuild turbos and finding ones that match is not easy. ebay will become a good friend. also fabricating manifolds will take some time. and of course i cant start till i find a new car to drive to work. but pics and details will be soon to come. any suggestions on cars to look out for good turbos in the junk yeard would be helpful or any other suggestion please feel free. even if its to tell me im crazy and it cant be done cause you are the one im going to prove wrong
