I recently found a 1978 Ford F250 4x4 CrewCab. It has apoximately a 4 in. lift and 35 in. tires; and sports a 460 engine mated with an automatic tranny. My question to you guys with similar specs or close to... is what kind of MPG you are getting; under all conditions. Unfortunately I do not currently know what gears are in the axle and what kind of CAM it has (towing, etc). Truck also has a matching topper, that may or may not affect fuel economy. Thanks
Randy ~ about 10 / 11 miles per gallon loaded or empty with the built 460. I drive my Chevette most of the time now since gas is getting so high @ $2.43 a gallon!!.... The Chevette gets 29 - 41 mpg depending on which way the wind is blowing.....
