Hissing under light to medium throttle
Since I bought this truck, it has a hissing sound that almost sounds like it is coming from the rear of the truck under light to medium throttle. As soon as I let off the throttle, it stops (Even if reving high). As soon as I rest my foot back on the throttle, the noise will come back - but only after a second or 2. I can't recall having this noise on my other '99, and wanted your valued opinion as to what it could be/if it is normal??
Also, the engine/exhaust is UNchipped and UNmodded (At least thus far).
Originally Posted by generalee31184
Whats the temp. out? Its your exhaust back pressure valve working to keep motor warm. Almost gaurantee it. Put some 5" exhaust like mine and you will hear a hissing you can hardly stand the morning. (well at least I imagine my neighbor cant) o well.
My EBPV kicked in the other night after I'd driven it over 30 miles. Went and ate dinner and when I came back it was pretty cold out, around 25*. EBPV was switching on and off for a few minutes. That's the first time I've ever noticed it doing anything once the engine was warm, kinda took me by surprise.
That thing had me wondering if my truck was about to blow when I first got it. Fortunately I found this site not long after getting my truck so I knew (figured out eventually..lol) what it was and that it was ok.
It could well be the EBPV that is kicking in on yours too. If it goes away when you mash the go pedal that should tell you a lot.
on
1 Post
try unplugging it and see if the prob goes away. let your engine cool so you don't get burning and look down in the valley of the engine at the front of the turbo near the botton and there is a 2 wire connector going into the turbo. it has a metal clip that holds it tight just rotate the clip up and pull the connector then drive it and see how it acts.
Originally Posted by Dsl Lover
It does go away when I either completely let off or completely mash the "go pedal" as you put it. So that would be the EBPV?
Like I said, I have to have a foot on the throttle to hear it (Can be very light to medium-heavy). As soon as I take my foot off, the noise stops. When I put my foot back on (Even if very lightly), it takes about a full second and comes back. I do not associate it with my brakes - only the throttle.
Originally Posted by Tenn01PSD350
Thanks for that kwikk. Had me stumped as does your answer 'cause I've never heard mine do that. Gonna be listening for it.
But it has to be aprox 50f or below for it to come on at all.
Pridnjoy
09-07-2013 08:50 PM
KevinAH
6.4L Power Stroke Diesel
11-03-2010 09:14 PM
Giuseppe1425
02-18-2010 08:19 PM
mattdf150
01-17-2008 02:00 PM
