I would say it is a Mopar 8 3/4 but I know nothing about them or Mopars. You could do a Google search for it or try to find a good Mopar site that discusses rear ends. Good luck
My god, my is going to end up part ford, chevy, dodge, and olds/pontiac. I guess i need to find some caddy and buick parts next.
Starting to sound like my truck. My build sheet includes Ford, Caddy, Buick, Olds, Pontiac, Chevy, GMC, Dodge, Chrysler, Toyota and range in age from 1946 to 2000
Okay guys, got the rearend out and the brakes unfrozen and the rearend turns. I do have some casting number if anyone out there can help me fiqure out what this rearend is or was. I appreciate any help.
easy to find, just plug in the number (2070742) into a search engine and let your computer find a match on the net.
"1-3/4" large stem pinion (aka. '742') Carrier casting numbers: 1634985 (1957-1964), 2070742 (~1961-1969). This assembly was replaced by a phase-in of the 1-7/8" pinion starting in the 1969 model year. 1970 RW (Plymouth and Dodge mid-size) were the last models to use the 1-3/4" which appeared in a 2881489 case. This assembly was typically used in high weight/medium horsepower applications through high weight/high horsepower applications. Pinion depth and bearing preload is set with shims. Differential bearing setting (ie. backlash ) is set with threaded adjusters."
Thanks guys for all your help. I have discovered that the rear is a 8 3/4 Mopar 742 which is the prefferred banjo stlye rear for many racers and street cars. I have yet to find what the rear exactly came of but it was a Bbody mopar from 65-69 according to the width specs. It is what mopar call a sure grip chunk and has a rebuildable clutches in the center clutches that was popular with many racers. I will probable use this rear since it was already mounted under a effie. I will leave a update later how its performance.
