Code 33
Big,
Hey my truck did the same thing,... but make sure it is the EGR valve before just replacing it.
Got mine at auto zone for kinda cheap,... but anyways...
Take a look at the metal pipe coming from the exaust, that connects to the EGR valve itself.
Mine was actually broken slightly, making the EGR valve not work.
Take your egr vavle off and wiggle the pipe, if it bends far or is loose and comes off, that is your problem. There should be a thermal asbestos wrap around the pipe, so it is hard to see if it is broken or cracked under the 302 intake. (if it is the 302 that you have).
Other symptoms.. could be the vacuum hose not connected or simple stuff like that.
Check back at me.
TONY Z.
#40
Check back at me.
TONY Z.
#40
I would stay far away from using Autozone stuff for things like EGR valves. Get motorcraft if possible, from someplace like rockauto.com. It's your truck, but more likely than not, it will cause problems for you eventually.
Pick up a Haynes manual. They have testing procedures for the EGR valve and the EVP. More likely than not, one of the two isn't working right.
Well its been a min sence I last posted. I have looked under the hood and can not find a vaccum leak. I think the is one though, When i run the truck it makes a wistling sound and when i shut it off it stays and then fades away. I would like to know if anyone can give me more insight into the meaning of code 33 EGR valve opening not detected. whats that mean exactly. I bought a chiltons manual and it sucks. If i want to replace or repair something its great. But wheres the trouble shooting section. I'm in the army and a mechanic at that and i have to say in my expearance with manuals, I know how to use them. But come on the chiltons manual, its horrible!
