No compression in #2! Arghh! Newbie
99 F-250 LD 5.4 auto I have been hunting out a miss and after doing plugs and swapping coils I finally did a compression test and found 5psi in Cylinder #2. I have not done a leakdown test yet but I was wondering other than a burnt valve could something else be amiss? Bad lifter or broken valve spring? Is there someway to tell if the valve is closing the whole way? Can I remove the rockers in the truck? I was thinking I could maybe remove the rockers on #2 and do a leakdown to be certain I have to take the head off. This has me sick to my stomach. I just bought the truck and it had a miss, at the time I was thinking plugs and a few coil packs and I'm good to go. Well this puts the icing on the cake! I am posting in hopes that something like this has happened to someone else on here and it hopefully isn't a burnt valve. Any help suggestions would be appreciated! Thanks in advance!
Nathan
Nathan
Did a leak down tonight without rockers on and it was 6%, The intake valve adjuster is holding the valve open and it drops to 85% leakdown. So... tell me there are shorter lash adjusters for when a valve job is done? I so hope there are, I am not pulling the head for one stupid valve hanging open a few thou. Thanks
Nathan
Nathan
