Draining gear oil
Old Mar 12, 2006 | 03:15 PM
rmalottwtes30's Avatar
rmalottwtes30
Draining gear oil
I am going to be changing the gear oil in my tranny (Ford 9") And I would like to know how to get it out of the rear end, do you have to take a stud out, suck it out with a gun, or take the whole thing apart? Thanks
Old Mar 14, 2006 | 11:52 AM
1975Ford's Avatar
1975Ford
To take the stud out will require removing the third member. Either way will work, but taking out the third member requires removing the two axles and third member, and is quite a job.
I perfer a siphon if your not have any other rear axle problems.
Old Mar 14, 2006 | 01:55 PM
rmalottwtes30
We tried the siphon with a siphon gun but it seemed like there was something in the way down in there.
Old Mar 14, 2006 | 02:37 PM
1975Ford's Avatar
1975Ford
Use a smaller diameter hose, clear, to fit through the hole , and between the third member housing and gears.
Old Mar 14, 2006 | 09:18 PM
thesprocket26's Avatar
thesprocket26
I'm installing a drain plug in my housing. Something to think about if/when its out next.
