ce light on
If the broken exhaust studs are allowing an exhaust leak on both sides of the engine, then, yes, they could cause the P0171 and P0174 codes. The leaks will upset the environment that the O2 sensors are in and cause the readings to be wrong.
While typically an intake system leak problem, especially the previously mentioned PCV hose, you've got another strong possibility that has to be checked and repaired
Steve
Steve
