rust
I'm a newmember here in FE and happy to be part of this site. I just bought a Ford F-250XLT Lariat w/ 90.340miles xtd cab fullsize bed, 460 7.5L V8. I'm the second owner and very exited about this truck. I would like to improve the brakes, any suggestions will help? Also i noticed a lot of rust spots on the roof area also the rear window panel area. How to I fix rust spots? The biggest one is about 1/2 in in diameter.
I just repaired the rust spots on the hood, now there are a couple on the roof. I suggest getting some 100 grit sand paper along with some 200 grit and sanding the spots right down to the bare steel. Then jsut get some primer and put a few coats on the area. You can either fill the area with a light coat of bondo, but really you wont be able to tell up there that its been sanded so I would just go ahead and get some automotive matching spray paint and give it like 5-6 light coats of paint.
If it doesnt match your original paint, at least the rust is repaired until you can get a pait job/body work done.
