Dooe manifold ?
Old Mar 9, 2006 | 09:36 PM
kreidhead's Avatar
kreidhead
Dooe manifold ?
I found an engine with manifold DOOE-3425-0.I realize it is a 1970 any help on the rest?
Old Mar 9, 2006 | 09:55 PM
greenhighboy's Avatar
greenhighboy
SCJ intake is DOOE-9425-C. Check the heads for DOOE-R. They are CJ-SCJ iron heads.
Old Mar 9, 2006 | 10:16 PM
kreidhead's Avatar
kreidhead
The heads are D3VE A2A the springs on them look alot heavier than stock ones I've seen.The block is D1VE-a2b I didn't get a number off of the pistons but they were ford but extremely domed with cut outs for the valves.
Scratch the block. The guy I got it from said that this wasn't the block it came with, so I don't know the # of it.
Old Mar 10, 2006 | 05:37 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome kreidhead to Ford Truck Enthusiasts!
We are happy you have chosen the best source for Fords.
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old Mar 10, 2006 | 09:53 AM
Brad Johnson's Avatar
Brad Johnson
Sounds like somebody put a CJ intake on a standard engine. Based on your observation about the valve springs, I'd pull the intake and see if there has been some head work done. You may have lucked into a set of ported heads.
Brad
mike1202002
Mar 3, 2016 08:45 PM
leftystar
13
Jan 15, 2008 11:18 AM
leftystar
Jan 9, 2008 06:46 AM
79f150TX
Apr 8, 2004 01:46 AM
1ole4d
Jan 27, 2003 01:10 PM
