View Poll Results: injectors or turbo
Voters: 9. You may not vote on this poll
injectors or bb turbo? which would be better
on my way to the doctor today, the engine just blew, no warning, no noise, crusing at 70 herd (more like felt) a big thump, looked back and saw the streak of oil the interstate. now since im gettin a new engine, i either want a BB turbo or some aftermarket injectors. just wanted to get some opinions. Ive got a 4 inch dp and exhaust, kwik filter, and a edge evolution and edge juice. also i can get a brand new engine from work, (i work at a ford dealer) for $6300 my cost just wanted to know if i would be better off going to international dealership or someware else. thanks
That's tough. I think the injectors would be easier to change with the engine out, the turbo can easily be done with the engine in. But, you'll need a turbo to support the injectors. Also, a BB turbo is more of an upgrade for a pretty stock engine. If you're doing injectors, a bigger turbo might be in order, an ddepending on how big of injectors, a bigger/dual HPOP may be needed too.
It all depends on how much you want out of your engine. If you plan to stay pretty basic, the BB turbo would be the choice.
Dude put your own engine together 6300 is more than im gonna have in mine with a complete rebuild and its not a stock build either. Im getting new heads, mahle pistons, Comp cams valve springs, machine work, balanced, hardened rods, chromemoly pushrods, main studs, rebuild kit... for right around 5k. Shop around you wallet will thank you.
id like to shop around but theres a nice hole missing out of the side of the block right where it meets the oil pan the piston got cocked sideways in the cyl and made a nice grove in it. where can i get some forged rods at i cant order them from ford i just get what they got, and i doubt the ones they have are forged
http://www.dieselinnovations.com/di....products&cat=7
Got an 01-03 Motor and Need REAL Rods??
You have been asking for them and we found them!!. These are reconditioned factory rods that are ready to bolt in to your short block.
Complete set of 8 - $480
