Getting ready to replace the brakes on my '02 EX 2wd
I inspected the brakes on my EX earlier this week because I was planning to take it on a long trip which would have included quite a bit of mountain driving. I found the rear pads were worn too thin for the trip and the fronts were also questionable especially since one pad was worn more than the others. The rear rotors looked fine but one of the fronts had some gouging on one surface as if there may have been metal to metal contact. I'll probably end up needing to the replace the front rotors as a set. I've never noticed any pulsating from the brakes while stopping. The choices for pads and rotors seems quite extensive. I don't plan to tow anything but I want the brakes to be up to the job if I ever do.
What are the best rotors and pads I can get that will last? I've read here that OEM rotors are prone to warping but how about pads? I've always used OEM on most everything I've owned and they met my expectations. The aftermarket stuff has been hit and miss but mostly miss. Should I replace the calipers? They still looked good and didn't show any signs of leakage.
Thanks in advance.
Thanks in advance.
I have a 2001 4wd that I use as a tow vehicle for our camper. When I did my front brakes I went with Power Stop Z36 Truck & Tow kit. Came with pads and rotors. I have been happy with it and have had no issues.
It was a little more than some others, but since I would be putting on a lot of towing miles I didn't think it was a place to cut costs.
Looking at RockAuto the 2wd kit is quite a bit more though. $348 vs $190. Not sure why the big difference.
The following users liked this post:
I dont know how relevant this is to your situation. I am also researching new rotors and calipers for Bertha's front end.
https://www.355nation.net/threads/no...d-drums.41051/
