Need this vin tag decoded please....
Old Feb 28, 2001 | 07:10 PM
greentruck's Avatar
greentruck
I have info off a friends tag thats all painted up, and the only thing we got is the numbers, not what they mean..can someone help me out with this? For a 70-71 F250, tag reads a follows:
F25yeh70387
131 A F253 L 4 F 38
6100 170 4100 11
F25yeh70387 A 11
F253 4 38 F
I just need the blanks filled in...Thanks Chris
Old Feb 28, 2001 | 10:14 PM
Ford79's Avatar
Ford79
Try http://www.medicine.wisc.edu/~mrm/bronco/vinford.html
Old Mar 1, 2001 | 12:27 AM
fozzy's Avatar
fozzy
F25yeh70387
131 A F253 L 4 F 38
6100 170 4100 11
F25yeh70387 A 11
F253 4 38 F
f25: Richmond,VA. FORD plant
yeh70387: paint code, not sure of numbers
131 A F253 L 4 F 38:wheel base 131",power steering, front axle GVW 6100/rear axle GVW4100, warner t-18,or new process 4 speed trans
dana 60 3.73 ratio, and I belive that is a 351W in your vin#, I would need to know codes from your driver door jamb
hope this helps, its kinda tricky with all the options, but the tranny and paint are the only ones not clear to me
https://www.ford-trucks.com/dcforum/User_files/3a9df0394b631ce6.gif
77'FORD F150 XLT 400
Old Mar 1, 2001 | 01:12 AM
DAV1972's Avatar
DAV1972
Is there any hint that the orig color could be black?
Old Mar 1, 2001 | 08:29 AM
fozzy's Avatar
fozzy
actually, I was leaning toward jade then I new I must be far off , I have only seen one jade /chartreuse f series!!!
My books are a little difficult to follow in the paint/body code section
Old Mar 1, 2001 | 06:10 PM
greentruck's Avatar
greentruck
>F25yeh70387
>131 A F253 L 4 F
>38
>6100 170 4100 11
>F25yeh70387 A 11
>F253 4 38 F
>plant
>of numbers
>131 A F253 L 4 F
>speed trans
>clear to me
Actually the color is Black ( tis tag is off a 70 f250, the owner bought it new, he's like 80 something ( really neat guy) the truck is beautiful...has 32K orig miles)..my truck is a 71 with 60k but no door tag so I'm trying to figure out the #'s so I can have one made for me (these two trucks are Identical, 'cept his has the Ranger package, and mine was repainted red (therefore no tag!)I plan on using his #'s minus the VIN for the new plate...
I thought the 6100=GVW 131=hp 4100=@rpm: I need to know what the L, 4 and the F are: the rest I know.. eng is 360 w/ 4sp thansk for the efforts...C
Old Mar 1, 2001 | 06:12 PM
greentruck's Avatar
greentruck
Lots of hints it is black....just that door or jamb was repainted...not the whole truck thanks Chris
Old Mar 1, 2001 | 07:07 PM
mk's Avatar
mk
F25- F250 series
Y- engine code (possibly 360)
E- assembly plant code
H70387- sequential unit number
131- wheel base
A- color code
Old Mar 1, 2001 | 11:53 PM
DAV1972's Avatar
DAV1972
My book shows an A code as black. Could the door have been replaced in the past? Check the VIN stamped on the frame to see if they match.
Old Mar 2, 2001 | 08:24 AM
mtflat's Avatar
mtflat
As I read it, L = Interior trim scheme (parchment)
4 = Seat (vinyl)
F = Body Code
Also, the serial number for 1971 used prefixes J-M.
Old Mar 2, 2001 | 02:17 PM
buzzard's Avatar
buzzard
