shaker hood for 85 f150
Old 03-03-2006, 07:47 PM
primer85f150's Avatar
primer85f150
primer85f150 is offline
Question shaker hood for 85 f150
has anyone heard of a shaker hood for 80- 96 f150 ?
Old 03-03-2006, 08:30 PM
toyscout2's Avatar
toyscout2
toyscout2 is offline
I haven't heard of one. However, it is not very hard to do. I made a shaker hood for my 1978 IH Scout. I used a TA scoop, but any scoop will work. Get the complete scoop, including the bottom part to hold the air cleaner. After determining the correct placement for the hole, cut a hole in the hood to center the scoop above the carb. I used an aluminum velocity stack ($10 at a swap meet) to join the scoop base to the carb at the correct height for the hood. I built some supports out of 1" aluminum to hold the entire unit. To cover the hole after I removed the snorkle, I wrapped a 3 inch wide strip of stainless around the entire base of the air cleaner.
Old 03-03-2006, 09:06 PM
SuperSnake's Avatar
SuperSnake
SuperSnake is offline
Do you have pictures?
Old 03-05-2006, 06:19 AM
toyscout2's Avatar
toyscout2
I looked around and can't find any pictures. Unfortunately, the scoop has been replaced with a 4-71 blower sticking through the hole in the hood. I will look around some more and see if I can find some old pics though.
insane_goofball
11-03-2011 07:49 PM
F150BOB1
2004 - 2008 F150
06-14-2008 03:51 PM
kilog55
04-13-2007 08:11 AM
SwOkcOffRoader
28
11-30-2006 09:07 PM
Quick Reply: shaker hood for 85 f150
