i bought a c6 transmission and a z-gate shifter now do i need a new flywheel and a diferent drive shaft what kind of drive shaft iam i looking for please any help would be nice thank you
Welcome to FTE!
Yes and yes, you need a flexplate and block spacer plate, and a new front section for the driveshaft. You might be able to use a driveshaft from a 67-72 truck with the same engine and transmission, but only if the transmission is from the 67-72 era.
