why does my 312 pop and backfire when hitting the throttle?
Another possible cause is the timing belt has jumped because it is worn. It is a common problem on the Y-block with lots of miles. You can check it by turning the engine by hand to bring the #1 piston at top dead center and looking at the timing pointer on the crankshaft to see where your initial timing is at. The manual says it should be 3 to 6 degrees BTDC.
Gerry and Roger,
Thanks for the suggestions. I'll check them today.
I put new spark plug wires and fresh plugs in. I am using the Autolite 46 recommended by the auto parts store. Set the gap to .035". The old plugs were a mix of brands and tip sizes. I put a timing light on it and got it to 4 degrees TDC. It continues to run strong under load up to the mid-RPMs where the popping starts. At highway speed, maybe 60 MPH in 3rd gear on the manual three speed, the popping continues. But it sounds like it is just one or two cylinders.
I just received my 1958 F-100 shop manual. I was planning on checking the distributor system against the manual today. I have also downloaded a manual for my Edelbrock card and will be fine tuning it today.
I had a shop adjust the vales and replace bent push rods during a major tune-up. Could my problem be something in the valve train?
Thanks,
Dave
Thanks,
Dave
Thanks all for your help. My '58 F-100 shop manual arrived from the good folks at NPD and what a wonderful read. Furball69, thanks for trying to be gentle with me about the possible blown head gasket. The manual is very specific about how to use compression tests to differentiate valve from ring from gasket problems. I do want to keep my Y-block, although a donor 302/AOD has a certain appeal, so I'll use the manual to troubleshoot and repair my loadmatic distributor and check the compression.
Thanks again to all of you for your advice and help. I'll let you know how this turns out in a future new thread.
Dave
Dave
rockrig4x4
Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150
12-16-2016 11:15 PM
LIF150
26
12-20-2011 12:00 PM
LIF150
09-12-2011 03:59 PM
Dave58
17
10-25-2006 04:31 PM
JSKIER24
12-29-2001 11:10 PM
