Manitoba / Saskatchewan Chapter Join Chapter, Leader: Fomoko1
tailight bezel dents
Old Feb 27, 2006 | 12:49 PM
Snowking's Avatar
Snowking
On my 57 styleside the tailight bezels are majiorly dented up. I don't know if anyone knows what I'm talkin about, but the reare roll pan blocks any rear acess to pound these out.Does anyone know how I could take these dents out without cutting up the rear end of my truck.
(I'm guessing there is no way, I had a post on the 48-60 and I'll I got in reply was that I would have to cut up my rear.)
Old Feb 27, 2006 | 01:33 PM
Mil1ion's Avatar
Mil1ion
Other than drilling strategic holes to insert a slide hammer pull.... then fill the holes ..then No
Old Feb 27, 2006 | 02:13 PM
Fomoko1's Avatar
Fomoko1
Drilling holes to pull out the dents with a slide hammer can work very well. It`s about the only way other than using a plasma or possibly a zip cut to carefully remove the sections for the repair. Cutting off the sections to straighten the metal gives the best access for the work. This one way to avoid using too much bondo.
No matter what method is used it will still be a time consumming task.
Lockups may have a better answer if he sees this thread.
Old Feb 27, 2006 | 09:38 PM
preppypyro's Avatar
preppypyro
I would say the slide hammer too, they work very well. All depends exactly where your dents are and how bad too.
Old Feb 27, 2006 | 11:44 PM
Fomoko1's Avatar
Fomoko1
Most of the time with no back bumper these panels are pretty beat in so I am willing to bet it ain`t nice.
Old Feb 28, 2006 | 01:09 AM
laynrubber's Avatar
laynrubber
I talked with a fella at Super Run this past summer and what he did was cut both ends off, lay them out and pound them back into shape. Then rewelded. Lots a work
Old Feb 28, 2006 | 01:13 AM
Fomoko1's Avatar
Fomoko1
That`s what I was thinking but you put it so much clearer. It`s lot of work no matter how it`s properly done.
How where your`s when you got your truck?
Old Feb 28, 2006 | 07:52 AM
preppypyro's Avatar
preppypyro
Sometimes lots of work is really worth it in the end, makes for alot better of a job.
Old Mar 2, 2006 | 04:13 PM
laynrubber's Avatar
laynrubber
Mine are dented top to bottom and maybe the tail light panel was cut off and poorly pounded out because there is a non factory weld all up that seam.
Again the previous owner not doing it right the first time
Old Mar 2, 2006 | 10:36 PM
preppypyro's Avatar
preppypyro
Makes it twice as hard to refix it the proper way.
Old Mar 6, 2006 | 12:50 PM
Snowking's Avatar
Snowking
I just did battle with those **** dents again on Sunday. It took me all day to achieve not a thing. I'll try once more but Mabye I'll just say heck with it. I know once I get them out some idiot will rear end me or something like that.
Old Mar 6, 2006 | 04:50 PM
66gpw's Avatar
66gpw
If it is sheetmetal. I will weld on a pice of metal with brass in the crease and hook a comalong to it and gently ratchet it out. Sometimes I have to do this a couple of times in differrent places. This usually works for me. It is a old trick from the body shop days. That way we did not have to cut out or try and hammer the dents out from an impossible to get at place. Also we had hydraulic wedges that would also push these areas out.
Old Mar 6, 2006 | 04:57 PM
Fomoko1's Avatar
Fomoko1
A unispoter would be ideal if you could rent/borrow one.
Old Mar 7, 2006 | 07:56 AM
preppypyro's Avatar
preppypyro
I am sure with enough playing around, testing and practice you will get it snow!
Old Mar 8, 2006 | 09:35 AM
Snowking's Avatar
Snowking
Yesterday because of the freezing rain I had neither school or work.
So with a above freezing temp. I gave her one last shot. The passenger side I eventually got with the Porta Power, but I cut the bottom half of the driver side out (unwillingly) and put it in the hydralic press. I still haven't remounted it but I am finally pleased. (until next time)
