Ignition issues
Ignition issues
so guys heres a puzzleing one for you...my 1990 f250 7.5 wont turn over.
i get power to the gauges
if i jump the relay the starter turns over
i replaced the ignition modual and the actuator rod hits it good
i replaced the lock cylinder
battery tested good
played with the neutral safety switch
I cant get the dang b*tch to turn over.
ill turn the key and all i hear is a click under the dash board.
any suggestions guys?
battery tested good
Actually no the reverse flood lights only come on if I jiggle the shifter **** on the column..it had a "sweet spot" then they would come on. I'm on 24 hour shift so I'll try crossing the wires tomorow when I'm off. The red and blue wires are the ones on the NSS on the tranny right? Cross those then try to start it with the key?
Fordwarden, this link is a for a 7.5L but it may help you.
https://www.ford-trucks.com/forums/689200-nss-replacement.html
jump the two wires that the NSS connects to complete the circuit.
Not sure what the wire colors are on your your model. (On the 1990 7.5L it's the white/pink wire and the red/lightBlue blue wire)
Good luck.
Good luck.
conrad10781
10-31-2018 07:39 PM
JJray
22
04-03-2011 03:28 PM
jrv
05-16-2008 08:49 PM
Kallie
1978 - 1996 Big Bronco
07-01-2003 03:07 AM
