Escape & Escape Hybrid Ford Escape, Ford Escape Hybrid, Mercury Mariner, Mazda Tribute
changing alternator
Old Aug 7, 2017 | 08:07 PM
  #31
got2bjoester's Avatar
got2bjoester
On my '12 the alternator is in the front. Looks MUCH easier to service. In fact, it looks like the removal of a splash pan is about all that's needed.
Old Aug 7, 2017 | 08:34 PM
  #32
DaveTV's Avatar
DaveTV
And that is the V6 not the I4, ya..?
Old Aug 8, 2017 | 11:04 AM
  #33
got2bjoester
Yes. They moved the alternator on the V6.
Old Aug 8, 2017 | 11:41 AM
  #34
DaveTV's Avatar
DaveTV
The engineer who designed the earlier alternator placement is in the witness protection program...
Old Aug 9, 2017 | 11:32 AM
  #35
got2bjoester
Old Mar 4, 2018 | 07:30 PM
  #36
Caloia1's Avatar
Caloia1
04 escape alternator replacement
Let me say this, both ways the top and bottom r a mother fu**** to do. I'm currently doing one now, I'm a full time mechanic from the bottom. Cv axle comes out and there still isn't enough room,.everyone says that's all u have to take out. Wrong, u have to take the axle out, and the alternator bracket out also, and then still it is really hard to get it out, ford messed up on the placement of it on these motors, literally no room to work, I would rather almost do a transmission replacement then this job. It takes me about 3 to 5 hours and I have 18 years experience. An the alternator bracket is kind of hard to take off as well the 2 bolts are easy it's the farthest bolt in back that is hard to get to. I used a 1/4 inch ratchet with a 3 i nch extension with 10mm socket. Then put all back together .and yes the plug on the alternator is hard to get off, loosen the alternator and take all 3 13mm bolts off first, then rotate it to were the plug faces up and get it off thru the top. It's easier that way. Both ways take about the same amount of time. I've done it from the top as well and you have to disconnect alot of hoses and the computer to do it that way. I hate doing them period.
wp120470
North Carolina Chapter
2425
Apr 11, 2023 12:03 AM
Brentburek
Jan 28, 2020 09:26 PM
BPofMD
Maryland Chapter
30
Jan 26, 2018 09:26 AM
Ron94150
Jul 31, 2016 07:12 AM
FordmanNJ
Mar 29, 2016 10:28 PM
