camshaft position sensor (problem)
I have a 96' f-250 PSD. supercab 4x4, I have 177000 mi. My problem is it is eating up the cam position sensors it started sending out a trouble code for this a few days ago. OK here is the bad part this will be the FOURTH one I have put inin the past four years ????????? What could be the problem causing this ??????
My CPS lasted 180,000 miles and now I am having issues with it again at 220,000. Has anyone tried this improved blue CPS? http://www.blackclouddieselperforman...54ed35c53d534b
Will it even work on the OBS psd?
on
i am not sure about the blue sensor. check out the thread in the superduty diesel section and see the exodus of people that have since taken theirs back out. not enough is known about what this sensor does to for me to feel safe using it. i have seen conflicting reports on what it does to the timing. one very knowledgable guy did alot of testings (he an IH tech) and found that it retards the timing by a few degrees and some "think" it advances the timing. too much conflict and not enough testing done for me. but yes if you get the correct revision it will work in the OBS.
Lanny
My F-350 died on me while I was pulling up to a red light in a turn, what a scare to loose PS then. I suspect the CPS but all I have red in other forums is it is an intermittent problem. When it died, it died and would not restart even the next day. The glow plug will not come on either. Is it possible to ohm out the CPS or check it with a test light?
The hunt for the Almighty Dollar!!!!
Americanism means the virtues of courage, honor, justice, truth, sincerity, and hardihood: the virtues that made America. The things that will destroy America are prosperity at any price, peace at any price, safety first instead of duty first, the love of soft living and the get-rich-quick theory of life.
Theodore Roosevelt
Theodore Roosevelt
price
Well each ford dealer can charge what aver thay went. I was lookj g for a front rim f350 I called 4 different places and got 4 dif price. I looked at were thay were at and In the richer parts of town the price was higher u try it and u will c. Even lows dose it and i have caught them. Was funny guy just could not back peddel .
