Fuel Pump eater
Old Feb 22, 2006 | 08:59 AM
dtony's Avatar
dtony
Fuel Pump eater
Hi All,
I have a 72 F100 with a 360/390 engine (not sure which, but they are similar). Since August 05 I have put 3 fuel pumps on it. For some reason they last about 2 months or 500 mines and simply stop doing whatever they do.
The last one (replaced last week) was pumping air out of both nozzles. Does any one know what could cause the problem? THere doesn't seem to be any physical damage to the pump itself. I am thinking that if this continues to put in an electric system. How hard is that?
Thansk,
Tony in New Mexico
Old Feb 22, 2006 | 09:20 AM
banjopicker66's Avatar
banjopicker66
Sounds like the seller is using the cheapest supplier, who is using the cheapest workers.
I would keep taking it back, or possibly pay the extra bucks for a brand new one.
If you go electric, you will need to put in the line a pressure regulator and wire it up, but that kind of work isn't that hard.
You will also need to get a pump block-off plate to cover the hole. It would be unwise to leave a afunctioning - albeit malfunctioning - pump working. It could introduce outside contaminants into the internal engine system if the diaphragm fails.
Old Feb 22, 2006 | 09:31 AM
dtony's Avatar
dtony
So, you think that the pumps themselves have been defective and caused by my truck???
Tony
Old Feb 22, 2006 | 09:41 AM
Chevy_Eater's Avatar
Chevy_Eater
No, caused by cheap Chinese labor. BP is saying buy a better pump.
Old Feb 22, 2006 | 09:55 AM
dtony's Avatar
dtony
Yep, that is what I have done. Went to a different store. The latest pump looks a bit different. I hope it lasts.
Thanks
Tony
Old Feb 22, 2006 | 10:20 AM
IBeam's Avatar
IBeam
A lot of people make the mistake of pushing on the actuater arm thinking they are testing it. This will either tear the diaphragm, or set it up to tear. The Cam offset will only move the arm a 1/4 to 3/8 of an inch in normal operation. Never test a manual fuel pump by pushing on the Arm.
Also check your fuel tank. Could be rust and or dirt in the tank. This will get into the pump and wear holes in the diaphragm. Put an inline fuel filter in it, or flush and clean the tank.
Old Feb 22, 2006 | 07:59 PM
baitmaster's Avatar
baitmaster
If you go electric, it is very easy to go with this setup. i have been using the Holley Red pump for several yrs with no probs. they are preset at 7lbs pressure, so no regulator is needed. the only thing I dont like about it is that it does have a bit of noise when it is running. They suggest that you dont mount it in a hot place (engine comp or next to exhaust). I also wired it thru a hidden fuel pump switch.
Old Feb 23, 2006 | 12:42 AM
ford390gashog's Avatar
ford390gashog
the pumps you buy at parts stores are not rebuilds. they are new. most are made by MASTER in the USA. you need to install them right. you always make sure the engine is at TDC when installing the pump.
Old Feb 23, 2006 | 05:42 PM
dtony's Avatar
dtony
I hate to sound like a dummy but what is TDC??
Thanks,
Tony
Old Feb 23, 2006 | 06:51 PM
Chevy_Eater
Thanks,
Tony
Top Dead Center. = zero out your timing marks.
Old Mar 2, 2006 | 12:52 PM
Yogi-96blazer's Avatar
Yogi-96blazer
I never heard of putting the engine at TDC Top dead center...
Old Mar 2, 2006 | 08:31 PM
baitmaster's Avatar
baitmaster
filters
I'm with IBeam, install a filter between your tank and pump. These old trucks have a lot of crap in the tanks, ( I even found 4 marbles in one of my saddle tanks when I removed it). I like the clear bodies filters with replaceable filters. Easy to see if anything is in there.
Old Mar 2, 2006 | 09:13 PM
dtony's Avatar
dtony
Yes, my rednecky brother said to do the same thing. A clear filter that is replacible. Will do.
tony
dtony
17
Feb 28, 2006 04:47 PM
dtony
Aug 19, 2005 01:35 PM
dtony
Jul 7, 2003 07:54 PM
dtony
24
Jul 6, 2003 03:12 PM
dtony
23
Mar 22, 2003 12:06 PM
