Batteries
Old Feb 21, 2006 | 07:26 AM
schlichtemeier's Avatar
schlichtemeier
Batteries
This weekend it was about 10 below when I tried to start my PSD. I didn't plug it in. Didn't get it started because the batteries wouldn't hardly turn it over. I haven't got the batteries checked, but to me this indicates I may have a bad battery. Any thoughts?
Thanks, Chad
Old Feb 21, 2006 | 07:51 AM
guzzle92's Avatar
guzzle92
At -12º F, not pluged in, running Rotella 5W-40, my F350 fired off with minor complaints. Even with thicker oil, yours should have turned over, even if you had GP issues. I would say it was time to have your batteries load tested. If you find only one weak, do yourself a favor and still replace both.
Old Feb 21, 2006 | 07:59 AM
whitesdford's Avatar
whitesdford
I had the same problem early this year. Batteries were only 2 years old, and they were 1000 cca. Replaced them with two fresh batteries, and if I forget to plug it in, it still spins like a top and fires right off.
Old Feb 21, 2006 | 11:39 AM
dagren99's Avatar
dagren99
Smile Batteries
Remember to replace them as a set. (pair) Since they are in parallel an old battery and a new battery paired together won't be as effective as two new bats.
DG
Old Feb 21, 2006 | 12:10 PM
Medic 66's Avatar
Medic 66
I agree.......when i replaced mine, i did them together
Old Feb 21, 2006 | 01:25 PM
schlichtemeier
When buying new batteries, what are the minimum specs I should be looking for?
Thanks, Chad
Old Feb 21, 2006 | 03:50 PM
turbostroke's Avatar
turbostroke
Typically 750 cca (cold cranking amps) at 0* for the psd's. Which will net you about 925-940 cca at 32*. So a 1000 cca battery would get you around 775 cca at 0*. Plenty for these trucks. Go much bigger the battery may not fit in your battery boxes/trays.
Old Feb 21, 2006 | 04:01 PM
PSNut's Avatar
PSNut
Good strong batteries are a MUST have for a PSD. The Intertsate Megatrons are a good choice.
Nut
Old Feb 21, 2006 | 06:44 PM
maevans's Avatar
maevans
I agree with nut, I've had mine for three years now and had no problems.When i'm out hunting and can't plug in, truck has always started.
Old Feb 21, 2006 | 08:06 PM
ggirten's Avatar
ggirten
I had a bad battery once. The truck turned over fine, but wouldn't start. It takes both to fire the engine.
Old Feb 21, 2006 | 08:07 PM
whitesdford
i put two interstate megatrons in, and they work great. Even when it just got down to -20, still spun over and fired in 3 or 4 seconds. Even plugged in it sounded funky for a while, but it was running.
