fried part of the main cab harness in the 79 :(
I have a bad short to ground someware between the headlight switch power feed and the fusebox but before the lighting curcuit fuse.
I thought it was the headlight switch circuit breaker, but the new switch went out in 10 minutes.
Its not a small short either, it pulls about 40 amps when you jump the switch.
and do a direct pinout on the connector.
thats how my sunday went
its a daylight only truck for a while
I didn't think there was a fuse in the headlight circuit. Power runs from the battery(or close junction) directly to the H/L switch and then out to the various lights. There is usually a fusible link at the power connection.
The dash and dome light have a fuse, but not the headlights. Maybe I am not remembering correctly?
