Sponsored by: Real Truck
Electrical nightmare....
Old Feb 16, 2006 | 10:02 PM
sorgegary's Avatar
sorgegary
I have a Superduty F350 that the drivers side door switch is not working properly. Sometimes at night the dome light stays on while driving because the truck thinks the door is open... It also wont lock the doors auto... Ill be driving down the road and the doors will lock randomly. Ihave tried to locate this switch but I am old shool and there is not a grounding switch that is visable........HELP!
Old Feb 16, 2006 | 10:34 PM
donjamer's Avatar
donjamer
The problem is the contacts get dirty just spray some WD40 on them.
Here is a link to another thread on this issue. This is one of many.
https://www.ford-trucks.com/forums/s...ight=Door+ajar
Old Feb 16, 2006 | 11:05 PM
112233's Avatar
112233
the contact wire or the switch (on the door latch itself) is loose, or has been mis-aligned causing it to read as if the latch is in the open position. remove the door panel and di-connect the wire. remove the switch with a 5.5 mil socket, clean the flange and bend it back into position. this usually occurs after someone has used a slim-jim on the door.(either attempting to steal the vehicle, or after locking the keys inside) we see the odd occurance of this at the assembly plant. the other possibility would be a bad or improperly (loose) grounded control module, and bad relay. but if the condition just started, (i am assuming a newer?? 2000 + model i would lean towards the door ajar switch itself. this would be the cheapest and first item to investigate.
Old Feb 17, 2006 | 06:59 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome sorgegary to Ford Truck Enthusiasts!
We are happy you have chosen the best source for Fords.
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old Feb 17, 2006 | 10:14 PM
sorgegary's Avatar
sorgegary
Thanks donjammer,
It took 30 seconds and all is well in the truck now I cant believe that I waited so long for such a simple fix.......
Old Feb 19, 2006 | 12:43 AM
donjamer's Avatar
donjamer
Originally Posted by sorgegary
Thanks donjammer,
Your wellcome, but I just relayed info from other threads.
