For once proactive and now serpentine squeak
For once I was proactive with changing out the serpentine belt (truck has 61K). I bought the belt from NAPA ( I have a dual Alt system). Now, when I start the truck I get a hiss like the belt is slipping as soon as the engine starts. I have also heard it when I am plowing and the plow pump is calling for juice.
Anyone else had this problem? I matched the belts when I installed the new on and everything looked fine.
Hmmmmmmmmmmm
Should have waited to change it out on the side of the road at 3 in the morning. Temp a balmy -10 degrees.
Hmmmmmmmmmmm
The other one I got was from checker, it was the top of the line one for the 7.3, like 40 bucks or maybe more, not sure, but its built a lot better looking at it compared to the napa one. No squeek either. Had my truck in for a fuel filter change, asked the mechanic about the squeeky belt, he took some tire chalk, held it against the belt for a few seconds, and the squeek went away. Two weeks later it came back, so it came off and now is my emergency belt.
If you want a good belt that will not make any noise buy a Goodyear Gatorback belt,Dodge trucks are the worst for having belts that make noise and the Goodyear will solve the problem.I installed a Goodyear belt on my 99 powerstroke and have had no problems.The belts that NAPA sells are made by Gates and they will make noise after a while.
