Upgrade Garret Turbo for 01 Diesel Excursion
Hello Everyone,
I have 01 7.3 Excursion and I'm looking for little more performance. I currently have after market exhaust system, Super Chip Tuner, Air Induction system. I am thinking about buying the Garret upgrade GTP38R. I was wondering how much of a performance gain will I see by simply adding the bigger turbo alone with the upgrades that I currently have? Would I need to go to a different chip to experience the difference in the bigger Turbo. Thanks in advance for your help.
Kimothy
Kimothy
Originally Posted by kimoh
Hello Everyone,
Kimothy
Kimothy
Once u shut down hearing it wind down is worth the $1600 price. Cat_man
can vouch here,amongst others.
U can also pick up either a 1.00 a/r or 1.15 a/r exhaust housing combined with your stock compressor wheel and the ATS housing you'll get appprox equal performance at about half the price.
Nut
Yea Nut is mostly right - the Garrett BB will provide lower EGT's, very quick spool up, but actually LOWER peak boost numbers, which is a GOOD thing, becasue it is more efficient than the stocker. With just a tuner - the 1.15 exhaust housing would be overkill, and would lose you some low end boost - I am very happy with the standard wastegated 1.0 housing even with my chip. I am thrilled with how mine performs and SOUNDS
upwards of 40psi boost safely, it's inherent in the design. Those cartridge bearings keep that shaft on center allowing it to go nuts producing more boost.
without seal failure like the journal bearing units.
Nut
Originally Posted by PSNut
Mostly right?....LOL! To be more specific,i believe the BB unit will run upwards of 40psi boost safely, it's inherent in the design.
Kimoh - yes you should see a noticable difference with the SCMT. If you are referring to the turbo, with the tuner, you'll find it spools up better the more fuel you feed it! It DEFINITELY spools up better on my 125 setting, than say, my stock setting, or even my low HP setting.
