Aod Tranny problems
Old Feb 13, 2006 | 02:50 PM
youngfordguy's Avatar
youngfordguy
Aod Tranny problems
Ok i just got a 88 bronco 2 and it has some tranny problems manual 1 and 2 work but no drive or overdrive. is it a comon problem or somthing serious. if some one can help it would be big help thanx
Old Feb 13, 2006 | 03:08 PM
stuart1's Avatar
stuart1
It is internal.
The O/R clutch is damaged.
Old Feb 14, 2006 | 01:31 PM
youngfordguy
Thats what i was worried about.
Old Feb 14, 2006 | 02:00 PM
youngfordguy
So has any one had to rebuild one of these and if so how hard and how much dose it cost.
Old Feb 15, 2006 | 06:00 AM
stuart1's Avatar
stuart1
I have rebuilt a bazillion of them.
The cost of the part involved isn't that much. It's what it takes with it that affects this.
Old Feb 17, 2006 | 08:31 PM
scottolan's Avatar
scottolan
I have rebuilt mine several times also.. If you don't have 3rd or 4th you broke something in the lockup system it's either the converter, the input shaft, or the direct clutch drum.. (or a failure of the splines connecting the components)... (I personally have broken every single part of the lockup system ATLEAST once in my 5.0.. LOL)
E-mail me at Shighsmith(at)treasury.state.la.us if you have any questions.. I have tons of rebuild pics I can send..
If you want to try and rebuild it yourself get the Technical Videos "Aod rebuild video" it is worth it's weight in gold.. It's very detailed..
The rebuild kit you should be able to pick up for about $100-$120
