I heard about someone removing the crossmember under the oil pan.
It weighs around 200lbs they said.
Has anyone here done that?
How is it accomplished?
That cross member is welded on for a reason.
Structure Strength. The whole frame system is built like a ladder, so you will need that crossmember as well as the one bolted to the strut rods and Transmission . Otherwise you will experience bad vibrations and frame failure.
