Should i change oil right after Seafoam treatment?
I read that if you treat the engine with Seafoam via the brake booster line, you should change the oil the same day because the Seafoam might eventually harm the main bearings.Wouldn't the Seafoam burn out more carbon if you drive a few weeks before changing the oil?
I poured 1/3 of the can in the crankcase and ran it for about 300kms in my truck, very drastic results, oil came out very black when it usually is a dark amber. No problems to speak of and I have put 20000kms since, I wouldn't do it again though.
I stay away from dumping anything else than motor oil. Too many things to worry about in a newer vehicle like expensive O2 sensors and such. I would have tried it in my old 300 I6 engine though, you just could'nt kill those motors.
I'd do whatever it says on the bottle, I can't remember what it says. Running it through the brake booster line simply cleans the TB and the combustion chamber, you should get little to none in your oil.
