Oil Cooler Rebuild Successfully Completed
We rebuilt the oil cooler yesterday. We drained all ELC including block. Two people are ideal for re-installation, especially to guanantee proper front gasket installation. Removing the entire oil cooler is optimal. You can get both headers cleaned, and slightly lube the inside of each header for easy re-assembly. The single most important step is the gasket placement on re-installation. Take your time on this step. We removed battery box so we could clearly see the front gasket from top and bottom to ensure proper placement. We did not address front header bolts through wheel well cover, though we did have a 30" extension. You can easily get you hand in there with a short extension to loosen and tighten them. Someone underneath can watch wrench alignment so you stay straight on the bolts when addressing them. We also disconnected power because of the block drain plug above starter.
Allot plenty of time to complete rebuild, so you are not rushed. If possibly, have a helper for the re-installation of oil cooler. This will ensure you do not have a horror story like the ones I am sure you have already read about if you have done your research. No shortcuts, the risk is to great!
Hope this helps & thanks Raymond for the excellent help!
on
I used a stiff plastic bristled brush, IIRC, to clean both the end pieces and get down into all the spots.
I was surprised when flushing how the flakes of crud just kept coming, even after I thought it was clean and clear.
I remember it as not being a very hard job, just time consuming with the flushing and cleaning, but from what I saw, it was time well spent.
Did you get a bunch of crud out of the cooling passages?
Did you install as one unit?
I will be replacing mine in the next week or two, new cooler, o-rings, gaskets, block heater, block heater cable, all OEM parts. Can oil cooler be installed as one unit, front and rear adapters pre attached or do I need to mount front adapter first? then cooler and
rear adapter.
rear adapter.
Arne, you could use some engine assembly lube such as the stuff in the link below.
https://www.amazon.com/Permatex-8195.../dp/B000HBNVSK
The front gasket is the hardest. We first used lube to hold it in place unsuccessfully. Then because we had the air/battery box, intercooler pipe, and power steering hose out, we put the oil cooler in place and could reach down in front of it and put the gasket on with one bolt and then line it up with the second bolt and tighten. Doing that way the gasket and header stayed perfectly clean. The back gasket stayed on with the lube the whole time and was very easy.
strokin'_tatsch
65
02-06-2023 09:36 AM
Macmathews
07-11-2016 10:43 PM
kent's f-350
12-14-2008 09:51 AM
