Aerostar Ford Aerostar
propshaft length and material
Old Feb 1, 2006 | 11:30 AM
x.l.r.8's Avatar
x.l.r.8
Having a brainstorm on another forum and we are wondering thelength of propshafts used in the aerostars, apparantly some had alu ones, if so which year and model, did the 3.0 5speed have a different prop, again id someone has one couls they measure the length from the centre's of the UJ's. I have a 91,92 and 95 all AWD all steel props so not sure if the alu information is correct, I know my props are 45 inches center to center, does anyone know of any diifferent lengths? and of course alu ones?
Old Feb 1, 2006 | 11:45 AM
copper_90680's Avatar
copper_90680
Hi X.L.R.8.
I thought there was a recall on the AWD (your '95 and earlier will be affected). Ford was supposed to install a new rear half of the Transfer Case, and put in an alluminum drive shaft. Why do your AWDs still have steel drive shafts?
The first thing I did when I bought my '95 AWD was to call Ford and they were able to check my VIN against all the recalls and that one was done on the van by a local dealer. They even told me which dealer did it and when.
Old Feb 2, 2006 | 07:00 AM
Pablo-UA's Avatar
Pablo-UA
I made a new propeller shaft after tranny swap. But I have the dual shaft. One (rear) pice is made of alluminium. I had no opportunity to use welding to add slip yoke to rear pice, so I have slip yoke in first pice of shaft. Argon welding was used for rear part. All the pices and assemled shaft were balanced to zero. No vibration up to 110 mph!!!!! Unfortunatly I don't remember its length, but I measured the length to desighne a shaft, when tranny was installed. Mistake in measures may be compensed by slip yoke. It is not dark now, so I will make some snapshots and post you. Have you e-mail? It will be easier.
Old Feb 2, 2006 | 11:30 PM
x.l.r.8's Avatar
x.l.r.8
Unfortunatly 110mph will not cut it and I relly need to keep a 1 piece, I'm thinking the aluminium one is only 1/2 an inch shorter then the 96 cobra one, well the auto should be, I just need to confirm this before I go on a quest for a drive shaft. FMS do a 3 1/2 inch OD one for $650 hence the reason to locate a cheaper alternitive.
Old Feb 3, 2006 | 12:29 AM
Pablo-UA's Avatar
Pablo-UA
Principally you can find a long, made of steel shaft, with 28.5mm u-joints and to cut it. But you need a lathe and welder. After that you need to find a shop, where your shaft will be balanced to zero. Yes, it is easier to balance dual shaft, but if you have an original engine and tranny you will not ride faster 80mph, so you dont need to have a dual shaft, especially taking into account that dual shafts require additional ajustment.
Just try to measure lenth from centers of u-joints. I did it with tape-measure (+- 1/8"). And visit all the local junkyards. I belive it will be sucsessfull.
Old Feb 4, 2006 | 12:49 AM
x.l.r.8's Avatar
x.l.r.8
looking at speeds of 140mph+ rather than 80, anyone know the changeover year or the recall year that the props became aluminium
Old Feb 4, 2006 | 01:52 AM
copper_90680
As far as I can tell from Alldata, 90 and 91 were not affected. 92-97 are all affected by this Transfer case/driveshaft recall.
Old Feb 4, 2006 | 02:27 AM
Pablo-UA's Avatar
Pablo-UA
Old Feb 4, 2006 | 05:18 AM
96_4wdr's Avatar
96_4wdr
Pablo,
nice job on driveline, hvy duty....is that an 8.8 inch Ford rear end?...
good looking tires, agressive tread, good for snow and mud
Old Feb 4, 2006 | 06:24 AM
Pablo-UA's Avatar
Pablo-UA
I dont know, it was found on one of local junk-yards... in very good condition. The gue on this junkyard told me, that it is the lust part from the SUV, but when I asked him what a SUV, he answered Ford. The rear axe is wider then original for 1-2". Brake drums are bigger, the axe is very heavy (i carried it to my van). It is self-locking, but if one wheel skids I feel a nock like someone noks my tail, but the van starts. There is no label. How to indentify it? I use it for winter, for summer I use original, becouse this one is slow (it seemes to me ratio is 3.9-4.2). I use the 2nd to start on green. And I drive over the city on 5th... Original is 3.37 as I remember.
I have 2wd only, but she really easelly runs on snow. Tires are made by Omsk (Siberia) tire plant especially for winter off-road. Size 225/70 R14. But these tires are not stabil on hight speed. I have old good Summit 215/70 R14 and Rosava (Ukraine) 205/65R15 for summer.
Old Feb 4, 2006 | 09:46 PM
96_4wdr's Avatar
96_4wdr
is this what you have? 9 inch Ford w 3 bearing pinion shaft, one tough mother, used in racing apps, highly prized and getting hard to find
http://www.ridgenet.net/~biesiade/Fordrears.html
here is comparison of 7.5" and 8.8"
http://www.usgear.com/tl/ford1.htm
probably 4.10 gears, great combination w the 5 speed
ur 5 speed syncro in all 5?, is 5th OD or direct?
have Omsk start exporting those mud/snows to the US, hard to find any decent deep aggressive lug tread over here for car/lt truck in smaller sizes 14 and 15" wheels
Old Feb 5, 2006 | 01:44 AM
xlt4wd90's Avatar
xlt4wd90
Gee, I didn't know that there was a 9" diff that came in the 3 link setup that the Aerostar uses. Unless the version of Aero that Pablo has uses a more conventional 4 link rear.
Yes, the Ford 9" diff carrier is stronger than other designs due to its pinion snout bearing. But this design has the pinion engaging the ring gear at the bottom of the ring, instead of the front:
9 inch: _O
others: -O
This requires a different cut for the gear teeth, which results in more friction in the 9 inch design than others, which in turn results in more heat from wasted energy. Most people using these diffs aren't concerned with the extra loss.
Also, based on Pablo's description, that carrier sounds like it has a locker type diff inside.
Old Feb 5, 2006 | 09:07 AM
Pablo-UA's Avatar
Pablo-UA
4th is direct, 5th-Od.
It seems to me one my axe is 7.5, the other - 8.8.
About tires. Many european companies make tires for snow. The mos popular are Nokian Hackapelitta and Good Year ultra grip here. But these tires are too expencive. 14" and 15" are popular sizes here. The most popular size is 205/70R14.
Old Feb 5, 2006 | 09:28 AM
96_4wdr's Avatar
96_4wdr
anything could be stuck under the rear of an Aero including a Mack diff with enough cutting and welding
Old Feb 5, 2006 | 10:04 AM
Pablo-UA's Avatar
Pablo-UA
I had an idea to add fwd axe to my aero and to make it 4WD, but the lust winter shows me, there is no reason. Good tires are chepper!
I've heard, that there are many problems related with 4WD.
And as say in Russia: better SUV, longer way to find a tracktor!
kengarchow
Feb 24, 2015 01:00 AM
Streaky
Apr 11, 2014 01:05 PM
techspec
Nov 14, 2013 09:23 AM
fordf350camper
Jun 11, 2013 01:51 PM
