well the trans is out and the clutch and pressure plate are off the only problem im having now is the bearing, apparently theres a clip in there that i cant figure out how to remove the manual is useless at this point
One of the great things about the F-250 I have is that the wheels spin long before the clutch does-no glazing issues. Having said that, I miss the 86 Bronc I had a few years ago (the turning radius was FANTASTIC compared to the F-250) so much that I figure its time to get another Bronc. This one will see some serious time and bucks put into it to make it the the multi-purpuse machine I've been wanting for years. Need to keep the big blue F-250 though, I need a work truck that will haul all sorts of construction stuff that the Bronc would have issues with.
