f 250 super duty no throttle
Old 01-18-2006, 05:02 PM
kingfreak
kingfreak is offline
kingfreak is starting off with a positive reputation.
if anyone out there can help me with this it wold mean alot i have been working on this thing for over 3 weeks no it is a 2001 ford f250 super duty with a 7.3 in it the problem ima hvaing it well not throttle it well sit there and run all day long just when u hit the pedel it well not do anything i have replace the petel and still nothing i got a friend that has a scan tool and i hook that up and it reads the pedel moving and all i have no idea what it could be i have traced down all the wires and all and can not find anything someone had told me it might be the pcm but iam not sure looking for a more info on it before getting anything else if u have any info please email me at [email protected] iam new to this site so iam not really sure if i can find my post after i leave here or not so if u could email me that would be great think you for your time and info
thinks again
Old 01-18-2006, 05:15 PM
Clint40's Avatar
Clint40
Clint40 is offline
Clint40 is starting off with a positive reputation.
I just went through this on a 2001. This will tell you alot. Go to the pedal and there should be 5 wires , check each one for voltage with pedal in its resting postion and then pushed down. The gray/white (postion 28 on pcm connector) will have the most voltage pushed down the others should have around 5 volts. BUT the yellow/white should have NOTHING!!! That is a ground and nothing else. all these wires go to the pcm connector at the firewall on the engine side and my wire nightmare was the yellow/white was pulled out of the pcm connector and had voltage on it when it shouldnt have. Go to the search bar for this thread and type in a key word ( my title was what the heck did I do I have no throttle) and go thru the process as I did. You will see many ideas there. If you cant find it I will provide a email to contact for more help.
Clint
Old 01-18-2006, 10:12 PM
cookie88's Avatar
cookie88
cookie88 is online now
cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.
Old 01-21-2006, 08:01 PM
kingfreak
thanks clint but that is not it either thia thing is about to drive me nuts and all the respones on yours did not help either if there is anything anyone knows please help if u need any more info let me know
Old 01-21-2006, 09:17 PM
Clint40's Avatar
Clint40
Clint40 is offline
Contact me and I will send you an email address for some help. Click on my name and the window will have a place so you can.
Clint
Old 01-25-2006, 11:23 PM
twinsfd
twinsfd is offline
twinsfd is starting off with a positive reputation.
10amp fuse for Power Train Control is blown. Grounding out because of a short on the overdrive switch wire , check steering column wires for bare wire, replace or wrap with electrical tape
Old 01-25-2006, 11:53 PM
BLK94F150
BLK94F150 is offline
BLK94F150 has a great reputation on FTE.BLK94F150 has a great reputation on FTE.BLK94F150 has a great reputation on FTE.BLK94F150 has a great reputation on FTE.
That's what it is. Happened to our 02 F250 at the Fire Department.
Mike
Old 01-26-2006, 05:03 PM
kingfreak
thinks guys but that aint it all is good with the fuses and all wires
Old 01-26-2006, 05:10 PM
BLK94F150
Did you check the underhood fuse box as well as the dash box?
Mike
Old 01-26-2006, 06:05 PM
ha305
ha305 is offline
ha305 is starting off with a positive reputation.
This just happened to me. Did your gauges go out. On my 2002 7.3 it was fuse number 45 went due to short.
bodyman36
11-04-2015 02:24 PM
resonateur
Ford Truck Parts for Sale
10-09-2015 06:05 PM
Keny1
10-22-2013 10:29 AM
rodeofooll
Indiana Chapter
08-29-2005 08:50 PM
Bomber1973
Aerostar
07-10-2004 05:03 PM
Quick Reply: f 250 super duty no throttle
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
