propane tank
Old 01-18-2006, 04:00 PM
mmmPowerStroke's Avatar
mmmPowerStroke
mmmPowerStroke is offline
propane tank
I was wondering what is the minimum size for a vapor draw propane tank. I heard you can't use just regular bbq tanks. What about a size like 10" diamatier by 27" tall would that be good enough?
Old 01-18-2006, 06:09 PM
351M's Avatar
351M
351M is offline
What are you using the tank for? I have seen 13.5:1CR 428s run off a bbq tank for 2 hours.
Old 01-18-2006, 09:41 PM
Dave Sponaugle's Avatar
Dave Sponaugle
Dave Sponaugle is offline
BBQ tank is fine as far as volume.
But it is not to safe bouncing around with a regulator on it.
DOT would frown if they saw that.
Old 01-18-2006, 10:22 PM
mmmPowerStroke
Propane injection
Old 01-19-2006, 12:38 AM
351M's Avatar
351M
351M is offline
Ok, definitly not legal. If you didn't mind the looks, a saddle tank off a pickup or a smaller tank from a car of some kind would do, but I assume it would have to be D.O.T approved for that purpose, otherwise I would even say a forklift tank.
Old 01-19-2006, 10:34 AM
powershotone's Avatar
powershotone
powershotone is offline
A RV horizontal vapor tank can be frame rail mounted or bed mounted. Horizontal tanks are ASME approved which means they can be permanently mounted. They come in all sizes. A 10 x32 is 7.9 gallons and will fit in between the frame rails of the Ford if you want to mount it underneath. Larger diameters such as a 12 x 32 is about 10 gallons so if you go in the bed, you can use one of these.
You can use vertical style tanks with a vapor draw system. They are DOT approved, which simply means they can be transported full or to be filled. Think of every travel trailer/pop up. They have to be mounted upright and secured so that they can't tip over. Mounting them in a vented toolbox for example works well.
Hope this helps!
Old 01-19-2006, 09:28 PM
mmmPowerStroke
Sounds good so pretty much anything will work just depends how much i want to refill it. So a couple on ebay for like $50
jonnybronco
Bio-diesel, Propane & Alternative Diesel Engine Fuels
03-06-2014 11:27 PM
krol
04-01-2008 10:04 AM
Red460
09-24-2007 10:36 AM
pjlandry
Alternative Fuels, Hybrids & Mileage
02-02-2007 09:56 AM
mmmPowerStroke
02-07-2005 07:37 PM
Quick Reply: propane tank
