F350 PowerStroke and NC Beaches
I've had a '97 Expedition and a '94 Quigley 4x4 5.8L van on the NC beaches and did well in the sand. I am about to order (tomorrow) an F350 4x4 CC Lariat diesel and am wondering how well it do in the sand with all that weight on the front axle. I've been going down there for about 15 years and can't remember many diesel pickups along the beach. Will I have any trouble with the stock 275 18" tires sinking in?
Thanks,
Mike D.
Thanks,
Mike D.
Thanks,
Mike D.
Thanks,
Mike D.
I was down there with my 99 F250 SD short bed extended cab(5.4) around 2000 and did OK. Pulled a stuck CJ out. Are you worried about the extra weight of the diesel on the front wheels? I agree that wider is better on the tires.
Are the NC beaches like the beaces where some cars can go out? Or is it a 4wd only beach. Either way you should be fine. I go out on assateague Maryland with my f350 with out a problem with my conti's. Recently just put some 325/65 terra grapplers that do a lot better then the contis. Just don't bury the truck, then you would have to do alot of digging. Mine is a diesel CC Long bed by the way.
lots of diesels out here on the inlet and tons of construction worker driving diesels 20-50mins north on the beach to carova everyday! stock tires really need to air down, but lots of guy's with 33x12.5 or 35x12.5 and up float without airing down unless the beach is torn up my buddy drive to carova everyday in his 2500 dodge Cummins with 39x16x16.5 has to air down if the beach is torn up but someday's does not even need 4x4! back in my young stupid days I took my z24 out on orgen inlet but it was very packed that evening HOPE THIS HELPS BEING I AM A LOCAL DOWN HERE
Captain65
02-13-2011 10:39 PM
kiwikingranch
1997 - 2003 F150
05-29-2003 10:24 PM
