1978 - 1996 Big Bronco
rear window defrost not working
Old Jan 16, 2006 | 11:17 AM
135crewchief's Avatar
135crewchief
When i push the button up front the light comes on but the rear window is not defrosting. Are the elements in the window just worn out or is there anything to check and look for.
Old Jan 16, 2006 | 12:09 PM
broncobob's Avatar
broncobob
Pull the access panel on the tailgate and make sure the wires are still connected to the defrost grid. They can get caught on the window mechanism and pulled loose. If they are connected OK, check for power with a meter or test light. You can also check for continuity through the grid when you have the tailgate open.
Old Jan 16, 2006 | 03:03 PM
pup55's Avatar
pup55
ya the wireing probally just got disconnected actually happened to me last weekend. was easy to fix
Old Jan 16, 2006 | 03:20 PM
suzuki989's Avatar
suzuki989
Mine went out too. I took the rear panel off and seen where the defrost wires rubbed off at the widest part, at the bottom of window. I tried the defrost repair kit and it didnt work. I'm gonna have to come up with something else.
Old Jan 16, 2006 | 05:16 PM
b4hntn's Avatar
b4hntn
I had power to the connections to the grid. Carefully sliding them on and off several times made the connections good again and the defroster now works. Also check the grey connector behind the bumper that has four wires, 2 to defroster and 2 to rear window I think.
fordtrucknut
37
Feb 5, 2009 04:19 PM
3headedboris
Mar 31, 2004 03:28 PM
killerklown
Dec 12, 2003 06:48 PM
Mr Baja
Jan 15, 2002 09:24 AM
sticky
Mar 21, 2001 12:09 PM
