Tough time towing today, WITHA TURBO!!!
89 F250 With the ATS Wastegated, c6 4.11 gears, i had the toughest time getting up around 60MPH into the wind though, once it was there it was fine, but it took foooooor ever to get there.
Downwind was a different story it still took a little while, but i could easily maintain 65-70 mph on level ground. But into the wind it seemed that i had my freakin foot in it the whole time. Any suggestions, i just had new injectors put in, and the timing has never been touched. I would like to turn my pump up just a touch, because i have absolutely no smoke at any RPM and i have no smoke even under a load.
Any suggestions, or comments. I have no pyrometer by the way.
Mike Howard
Mike Howard
Get a pyrometer and boost gauge first.
You may scare yourself once it is installed before you ever turn the pump up.
Install the thermocouple in the exhaust manifold for the best numbers, I did mine on the drivers side just above the cross over pipe connection.
Once you know what those numbers are we can make it better.
From my years in semi's I know the wind from any direction in the 180 degree radius around the front of the truck can be a bear. The hardest to go in was 45 degrees left or right of dead ahead. When you have to drop several gears on flat ground in a KT 600 Cummins to keep the EGT's under control you learn the power of wind real fast.
Received 3,102 Likes
on
driving down the interstate with the cruise set at 65. come up to a "wind tunnel" created by hills on each side of the flat road. all of a sudden, you realize you ain't going as fast as before, and floor it. your truck that can normally do 85+mph can barely maintain 50 because of the headwind, and the EGT's are running right at 1100º
It was much worse out in the high plains where you had hundreds of miles of nothing in the way to break the wind and hundereds of miles to get where you were going.
Plus the higher elevation already had the pyrometer going way on the high side.
Throw in a 30 MPH headwind and Kansas was like a brick wall 470 miles thick.
on
get a pyro, and a boost gauge--as per daves instructions--then turn up the pump two flats--and see where the temps are--and keep it below 12000 degrees--unless you want melted pistons------the shorten the wastegate rod till you boost reaches a max of 12 lbs--and still watch the pyro!!!!!!!!!!!!!!!!youll think you have a new truck------
