Daddy's got a new toy to suck up his cash!
  #31
Old 01-15-2006, 01:13 PM
texan2004's Avatar
texan2004
texan2004 is offline
texan2004 is gaining momentum as a positive member of FTE.
Christopher,
That photo is a great example of how wierd things can be. I notice the C on your fram rail was stamped over with a Y.
  #32
Old 01-15-2006, 03:51 PM
2000n55
2000n55 is offline
2000n55 is starting off with a positive reputation.
Way to go on the truck. Its cool that your son is helping you with it.
  #33
Old 01-15-2006, 06:41 PM
mrlightrail's Avatar
mrlightrail
mrlightrail is offline
mrlightrail is starting off with a positive reputation.
Still looking for the s/n on the frame rail, ain't found snot yet. On the up side, engine turns over. Pulled Radiator, fan belt and shroud, and turned the motor over with a breakover wrench... Surprised to see two thermostats! sheesh...
  #34
Old 01-15-2006, 07:30 PM
4tl8ford's Avatar
4tl8ford
4tl8ford is offline
4tl8ford is a splendid one to behold4tl8ford is a splendid one to behold4tl8ford is a splendid one to behold4tl8ford is a splendid one to behold4tl8ford is a splendid one to behold4tl8ford is a splendid one to behold4tl8ford is a splendid one to behold
The left and right cooling systems are seperate on the flathead, the only comon area is the radiator.
You can disconnect a water pump pull the head on that side and run the engine, don't know why ya would want to do that, but it can be done.
Look on the crossmember now that you have the raditor out and see if the SN might be there. A heavy wire brush will help there or as described before on the frame rail.
I wouldn't put too much faith in the on in the glove box, the plate and/or the glove box door can be swapped out. I've sent a couple out to folks fron Ol Trucks that will never see the road again.
mrlightrail
16
10-23-2007 09:02 PM
mrlightrail
08-01-2007 10:53 PM
mrlightrail
01-17-2006 12:19 AM
mrlightrail
15
10-01-2004 09:48 AM
mrlightrail
17
09-20-2004 11:10 PM
Quick Reply: Daddy's got a new toy to suck up his cash!
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
