Go Back  Ford Truck Enthusiasts Forums > Misc. > Offroad & 4x4
Reload this Page >
how much does yall's junk weigh?
Old 01-12-2006, 06:47 PM
KubotaOrange76's Avatar
KubotaOrange76
KubotaOrange76 is online now
KubotaOrange76 is a name known to allKubotaOrange76 is a name known to allKubotaOrange76 is a name known to allKubotaOrange76 is a name known to allKubotaOrange76 is a name known to allKubotaOrange76 is a name known to all
like i said...i was just wondering if yall have weighed your junk...
mine weighed 5,860 without me in it with 25 gallons of gas, and my tailgate i have on there now.... i carry about 500 lbs of tools and recovery gear
how much does yall's junk weigh?? have you made any changes that made big differences?
when i run in bogs i take everything out of the cab, empty the toolbox, and take out the jack, as well as loose the toolbox and all my recovery gear....nex bog i may take the front bumper and winch off...i thinking that would get me aorund 52-5400
i was just surprised i wasnt closer to 7k....
lets hear it
mines a 79 f-250 with 60 front, sterling rear, stock brakes....460/435/205, 1410 hd shaft in the rear....rear pipe bumper with d-rings, front warn winch bumper with 8274...headers single exhaust etc etc
76 f-100 lwb body w/ undercoating on it, and cut out fenders, im missing the heater and carpet
Old 01-12-2006, 06:50 PM
brokebronco's Avatar
brokebronco
brokebronco is offline
brokebronco is gaining momentum as a positive member of FTE.brokebronco is gaining momentum as a positive member of FTE.
Been meaning to get mine weighed. With all the junk in and on it it must be pretty heavy.
Chris
Old 01-12-2006, 06:53 PM
amish77's Avatar
amish77
amish77 is offline
amish77 is starting off with a positive reputation.
mines pretty much stock, running 3800 gross. Full tank o' gas and me in it it's probly closer to 4200.
KubotaOrange76
tell what your junk is...give some specs....at least the stuff that affects weight
Old 01-12-2006, 06:57 PM
Skipped_link's Avatar
Skipped_link
Skipped_link is offline
Skipped_link is gaining momentum as a positive member of FTE.Skipped_link is gaining momentum as a positive member of FTE.
My 79 supercab wieghs in at just shy of 5400 lbs,
The 03 diesel is at 6800 lbs
& the 49' ????? soon to be found out, hopfully between 4000 & 4500 lbs,
You could shave a few pounds by going to half ton disc brakes front & rear, then remove your stock bench seat & build a light wieght seat mount for a couple RCI or summit race seats, also a lexan or plexiglass rear window would be a few pound lighter than stock,
Old 01-12-2006, 07:36 PM
KubotaOrange76
hell yea, this is the kind of tech i was lookin for...i have rear discs planned, but im still waiting for the stock shoes to wear out...seems like its taking forever
any more tips yall got?
Old 01-12-2006, 09:02 PM
1BadB2's Avatar
1BadB2
1BadB2 is offline
1BadB2 is starting off with a positive reputation.
84 Bronco II
im 3300 dry and 3700 trail loaded..that includes my tuffbin full of tools, strap, jumper cables, chain, highlift, gas and me...sometimes a passenger.
Old 01-12-2006, 09:18 PM
amish77's Avatar
amish77
amish77 is offline
dana 44 is lighter than a ford 9
coil overs are lighter than leafs
could pull the 1980 f150 move and cut a bunch of holes in your frame. (that one ford did at the factory, great idea guys)
Old 01-12-2006, 09:33 PM
fishmanndotcom's Avatar
fishmanndotcom
fishmanndotcom is offline
fishmanndotcom is a name known to allfishmanndotcom is a name known to allfishmanndotcom is a name known to allfishmanndotcom is a name known to allfishmanndotcom is a name known to allfishmanndotcom is a name known to all
my 96 crew cab PSD with ranch hands front and rear and 35" tires weighs 7200lb with 2 full tanks
-cutts-
Old 01-12-2006, 09:36 PM
r0n1n's Avatar
r0n1n
r0n1n is offline
r0n1n is starting off with a positive reputation.
97 250hd ext cab w/ 460 is about 6600 lbs - me (195) my dad (190), and my tools (no idea), and about 20 gallons gas. stock d50, 10.25 rear
-jason
Old 01-12-2006, 10:05 PM
Kenworth
Kenworth is offline
Kenworth is gaining momentum as a positive member of FTE.
My 95 F-450 weighs 8400lbs with me and a rear tank of fuel my truck has a 12' steel flatdeck. My truck weighs empty what most P/Us GVWs are when fully loaded
Old 01-12-2006, 10:48 PM
RawPower's Avatar
RawPower
RawPower is offline
RawPower has a great reputation on FTE.RawPower has a great reputation on FTE.RawPower has a great reputation on FTE.RawPower has a great reputation on FTE.
7400... ranch hands tool box head ache me & my junk (tools and guns)
Old 01-12-2006, 11:05 PM
mustange70's Avatar
mustange70
mustange70 is offline
mustange70 has a good reputation on FTE.mustange70 has a good reputation on FTE.
Bit's n' Pieces weighs in right at 4800ish lbs after a bog, its an 80 3/4ton (swiss cheese frame believe it or not does make a difference by at least a couple hundred lbs), the body line on the bottom of the truck front to back both sides, everywhere but the cab was removed, inner rear fender removed, and plastic front inner fender were replaced by homemade canvass fenders, front gas tank removed, exhaust heat sheilding removed along with any useless hangers and junk, aluninum 4v intake, single exhaust chopped a foot behind the cab no muffler, front pice of metal from the bumper to the bottom of the grill trim removed, grill removed, well actually fell out , washer fluid resivour removed, in the interior the rubber mat was removed, stereo and speakers removed, glovebox removed, plastic kick panels/sun visors and trim along the windshield removed. Thats about all i can remember, but i know i missed a few items
Rest of the truck has a 400/nv-435/np-205, 60front/10.25rear 35x16x16.5 boggers, leafs' and dropped suspension mounting points.
Few things i want to do is to replace the rear bumper with a piece of square tubing (likely 1/4x3x3), seal it and plumb it for an air tank, i want to put a set of half decent comfortable raceing seats in place of the bench and a few other things that should drop another 150lbs.
Old 01-13-2006, 12:52 AM
ramboss429's Avatar
ramboss429
ramboss429 is offline
ramboss429 is gaining momentum as a positive member of FTE.
I'll let ya know tomrorow what my junk weighs. Any guesses?
Old 01-13-2006, 01:11 AM
monsterbaby's Avatar
monsterbaby
monsterbaby is offline
monsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputation
mine is 3620 for the ranger, and the F250 wieghs in just a tad over 7k
Quick Reply: how much does yall's junk weigh?
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
