3.8 head gasket question
Old Jan 11, 2006 | 12:49 PM
Old Blue Crew's Avatar
Old Blue Crew
I'm looking to buy a vehicle (2002-2003) with the 3.8, but have heard that 3.8's have had problems with blowing head gaskets. Does anyone know if Ford has fixed that problem, and if so what year did that occur? Thanks for your help.
Old Jan 11, 2006 | 02:39 PM
Old Blue Crew
Ford 3.8 head gasket question
Old Jan 11, 2006 | 03:50 PM
1956MarkII's Avatar
1956MarkII
Nothing to worry about with a model that new. The worst ones were mid-90's; you'd be hard-pressed to find even a '98 or '99 with a problem.
Old Jan 11, 2006 | 05:18 PM
94_turbo's Avatar
94_turbo
95,96,and some 97 windstars later no problems--ford tried a diff headgasket in those years--cars didnt seem to bother---
Old Jan 11, 2006 | 05:23 PM
924x2150's Avatar
924x2150
our 89 cougar with the 3.8L blew a head gasket, that is all I know.
Old Jan 11, 2006 | 05:33 PM
trike1946's Avatar
trike1946
My son had one. 95 I think. Blew the rear gasket. The other consideration is with his car there was no room to do anything. To replace the water pump you had to lift the engine. Probably they are better now.
Old Jan 11, 2006 | 06:57 PM
Fordsflylow's Avatar
Fordsflylow
Not sure about 95's, but I replaced the water pump and I never had to pull the motor!?! As for the head gasket problem, it was exactly that a problem with the gasket. I put on a Felpro at 100k miles. I don't think they're having problems with them now! Still running, riding, and looking excellent at 155k miles.
Old Jan 11, 2006 | 07:32 PM
yardbird's Avatar
yardbird
I had a '94 Mercury Sable that Ford replaced the engine in three times because of the head gaskets. The third Ford reman was put in in 2001. It needed another engine when I traded it in May 2002.
The car had plenty of power, but 30,000 miles was about it on a set of head gaskets.
Old Jan 11, 2006 | 07:33 PM
Grandpa's1983's Avatar
Grandpa's1983
We used to do 2-3 head gasket jobs a week in our shop in the 90's but haven't seen one in a long time now. Ford stopped using the 3.8 in the Taurus/Sable platform in 1996, and the changed the design in the Windstar and Mustang about the same time.
Old Jan 11, 2006 | 08:16 PM
go_racing84's Avatar
go_racing84
I know for sure that the '99-up V6 3.8s use a different head design that is far less prone to this kind of failure. The older design put a few water passages very close to the fire ring, and that's where they fail. The newer design uses coolant passages much like the Supercoupe motors used which are shaped differently and moved away from the combustion chamber.
FWIW, you can pretty much eliminate the problem in the older motors by making sure your heads and block are very true, using a good gasket (Felpros are good), using brand new ARP head bolts, and making sure you keep your cooling system in good shape.
Old Jan 12, 2006 | 05:43 AM
trike1946's Avatar
trike1946
Fordsflylow, it was a Taurus. When he bought it he got a 90 day warranty on it. Luckily the water pump went in two days. The dealer replaced it and said they had to lift the engine. I didn't do it so I am only going from what they say. When I looked at it, I could see it would be a real bear to change. No room anywhere.
Old Jan 31, 2006 | 10:49 AM
Hamberger's Avatar
Hamberger
I hate to admit but I find it difficult to find pride in my 95 Windstar with the 3.8l V6.
I drive it easy, we are talking to church on Sunday and back, that is about it, and yes I go to church every Sunday and the wife uses it to drive the kids to school.
I had to do a total Tranny rebuilt at 130k,
The timing cover gaskets starts to leak every 40k to 50k and yes you have to drop the A Frame with engine and transmission every time the gasket needs changing.
Replaced the Engine Head Gaskets at 150k,
Replaced a cracked front cyliner head and new head gaskets again (casting defect) at about 160k,
The entire ABS system has been a real wallet drainer.
Starting to see antifreeze puddles on the driveway again, I guess I am due for another timing cover gasket.
Spent last weekend replacing the Power Steering Pump.
