Head Gasket: Steel Shim or Fel-Pro
I am currently in the process of putting my engine back together after a rebuild. My current set-up is going to be 390 .060 over, comp 268h cam, headers, dual exhaust, edelbrock performer intake and edelbrock 750 cfm performer carb. I currently have the fel-pro gasket set I am using. It also came with a head gasket. I have heard that many people do not like the fel-pro head gaskets as they are too thick and lower compression. Instead everyone seems to prefer the .021 steel shim. I am thinking about purchasing a steel shim, but was wondering about the reliablity of them. When coated with the copper spray, will the steel shim be just as reliable as the fel-pro? I would like to use the steel shim, but don't want it to leak. Anyone have any feedback? Thanks
That sounds like a plan. I was leaning towards the steel shim as I do not want to take compression away. My heads and block just came back from the machine shop. The heads were plained and the block was checked. Will any copper spray work fine? Also on summit.com it says the Mr. Gasket steel shim will only work on upto a '71 - 390. Believe mine is a '74. Will it still work?
Copper spray is fine. A 74 block will not make any difference either. I'm guessing you have iron heads which are fine with the steel shim gaskets. You can also install them dry. Some of the old 427 steel gaskets wicked coolant through them on the deck and were installed dry. I use acetone or lacquer thinner to clean everything first. I start at 20 ft lbs and go up in 5 ft lb increments to 95 ft lbs. Go over them again and call it good.
G.
G.
you can overnight the steel shim head gaskets from Summit. They're $20.99 for a pair. I think they charged me $15 for overnight and I had a couple of other items as well. If you really want the steel shim gaskets I'd get them now and not have to tear into the engine again.
Good Luck!
Tracy
Good Luck!
Tracy
check www.mrgasket.com. They show several distributors. I checked JEGS and they show having them although you might want to call and verify. Their part # is 720-1132. I'll bet you can find these somewhere without too much trouble.
Good Luck!
Tracy
Good Luck!
Tracy
Spktyr
12-16-2016 10:18 PM
JoeVR5
1983 - 2012 Ranger & B-Series
08-09-2011 09:07 AM
Sock Monkey
08-04-2010 04:52 PM
ceetwarrior
20
12-21-2003 01:44 AM
