Auto/Manual hubs
Auto/Manual hubs
I know this topic has been beaten to death, but I have a relatively new-to-me '02 F250 4x4 with the auto/manual front hubs and the ESOF. From reading these forums I know that these hubs are known for losing their "auto" functionality. So, last night I shifted the dash **** to 4-Hi on an icy road and started a 3-point turn with the hubs in the auto position. I probably drove about 35 feet after turning the ****, but in the reverse portion of the turn only my left rear wheel was spinning on the ice. I rocked back and forth from drive to reverse seeing if that would engage the front wheels, but nothing. Got out, locked the hubs and was on my way with good traction. Should I just assume that my hubs have lost their auto function like many others?
Should I just assume that my hubs have lost their auto function like many others?<!-- / message --><!-- no sigs except when logged in -->
Sounds like if only the left rear was spinning you could use an Auburn limited slip too.
Are you sure they'll stay locked?
My '01 F-150 had a manual shifter on the floor with no electronic switch and no hubs to lock in. I loved that system don't know how it worked but it always worked. I put a lot of miles on in the winter and dont like to have to run with the front axles and drive shaft locked in just incase I come upon a bad strech of road.
I like to be able to shift in and out when needed. The 150s system worked great in that sense.
When I ordered my new '06 SD I went with the shift on the fly, due to reasons mentioned above. I dont like the idea of electronic shifting it just seems that its just another thing that can fail when you really need it.
Has anyone had any problems with the SOTF system or is there anything I should look out for.
Your F150 had the "Center Axle Disconnect System" on it. Lots of rotating mass even when you're not in four wheel drive. It's also the same system used by GM & Dodge. What you're referring to as "SOTF" is known as Electronic Shift On the Fly or "ESOF" for short. They are no problems with the servo shifted transfer case. There are LOTS of problems with the vacuum shifted hubs which is why a lot of us have switched to manual hubs. A new auto hub for the Super Duty runs $300 per side and it will eventually have the same problems as the originals did. As a comparison my MileMarker manual hubs ran $158 shipped and will outlast the truck. The MileMarkers are a "Mil-Spec" level of quality that Ford should offer as an option on the new trucks to improve their "cred".
Depends on how long you plan on keeping the truck. The stock hubs are junk; sooner or later they're going to fail. Some people disassemble them and lube everything. Sometimes it works, sometimes it doesn't (mine didn't). Eventually, though, you will be left with a truck that is either always in 2wd or always in 4wd. If you plan on getting rid of the truck in the fairly near future, then I'd nurse the stock hubs. If you see the truck being in your driveway for more than a year, do yourself a favor and get aftermarket hubs. I've got MileMarkers, but I've also heard good things about the Warns.
Originally Posted by swenson
I've read the same thing about the vacuum lines on this site several times. Wouldn't that be a better place to look first rather than just swapping out my hubs?
A two person operation: Check the vacuum actuator. It should provide suction power for 20 seconds going into 4wd. It should then provide about 5-10 seconds for going from 4wd into 2wd. Check the suction at both the actuator itself and the spindle/hub. If all is well, then go for the hub removal.
Hope this helps...
biz
bad hub seal or yoke seal
My hubs failed to lock and I traced to problem to a bad yoke seal. I could not pull a vacuume as per the service manual and mine ended up being a bad yoke seal. The yoke seal is behind the bearing hub and seals the drive shaft to the wheel spindle (yoke). The new seal is a pain to drive on but after 2 hrs and 34 bucks and it worked again. Best part---I still have auto hubs.
MOOKIEX4
1999 to 2016 Super Duty
11-03-2015 10:15 PM
troverman
12-16-2014 06:41 AM
99 F250 SD 4x4
05-19-2014 07:07 AM
Biscayne
11-18-2012 06:24 PM
