2006 F-150 aux input
Hi
I just got my new ford - I was wondering if anybody knew how I might tap into the aux input on the single cd/radio unit?
I have not taken the unit apart yet want to know if it is worth it. I went to my dealer - they had no clue - I emailed ford I told them what the dealer said asked for their help - they said to get a helm book and/or contact my dealer (guess they didn't read my email completely).
Thanks
Thanks
You might try searching for "aux" or "p.i.e." ... etc. Quite simply, you'll most likely find it extremely difficult (if not impossible) to tap into the aux input. The brains behind the head unit are such that you are VERY limited in modding it. The aux is only supposed to support the Ford DVD add-on. There is an aftermarket cable that's now available which has allowed others to hookup iPods, satellite, etc.
http://www.discountcarstereo.com/detail.aspx?ID=813
Originally Posted by RangerWask
My biggest question is where does the input go so you can plug the ipod in... sorry, unclear from everything i have read (and yes, I have done the searches, no one has posted pics)
Jack
Originally Posted by swhite005
Open the ashtray...Pull the trim around the radio and AC controls from the bottom, just above the ashtray. The trim piece is held in by 4 clips, no screws. Once that is off, 4 screws hold the radio in place. When the screws are removed, pull stereo out and plug PIE into proper outlet.
Once you have that panel off rest is easy. Start at bottom and increase pressrue evenly on both sides until the first two pop.. then you will have the idea..
Jack
jv-10
01-04-2009 09:32 AM
Stefan A
12-01-2004 08:22 PM
