Ok, so I purchased a toronado for my 7.3. I don't know if that was such a good idea or not. Supposedly it is supposed to give me better air flow into the turbo but I am not sure it works well with a turbo. Does anybody have any input about the toronado
Popular Mechanics did an article on it and their conclusion, that it was junk. From what I learned in my engine class, I fail to see how it works. All that swirling is causing low pressures zones and bacause of that you are not getting a clean, smooth flow of air to the intake or turbo. I know from working on turbine engine, when you low pressure zone in intake air flow if it is severe enough it will cause compressor stalls. Just my 2 cents.
