The block of wood will keep you from destroying the metal ring, but it also prevents sparks. Be aware of the potential danger from sparks, but it's not as big a deal as with gasoline.
i was using a brass draft but it wouldnt seem to budge just wanted to make sure there wasnt a trick i was missing. gotta do the tank mod i got the dahl 150 in and cant belive how much air comes through it right now. or i got a fitting leaking...that i cant find...
its fixing the pickup tube so it dosnt mix with returned fuel. so your not getting heated airerated fuel. search for hutch mod, i gotta run ill go into more details later. but this was derived from a guy named hutch. there should be some good writeups or ask kwikk for the writeup link.
