metal shavings in my differential
About a week ago I started noticing a whinning noise coming form the rear of my 04 sport trac. Today I took it in for an oil change and asked the guy there to check the fluid in my differential because of the whinning. He came back up with the plug. The plug have a considerable amount of metal shavings on it along with some metal chunks. Since my truck is still under warrenty he told me to go to a dealership and tell them whats going on. The people at the dealership said that it was normal to have a few shaving and told me that there was nothing wrong. I'm in a bind right now, one person is telling me that it is ok and another telling me it is very bad. What do ya'll think and what should I do?
Thanks
Thanks
Thanks
Thanks
Run - don't walk - to a different dealer and turn it in. These modern trannys should not habve shavings in the fluid. You're going to have a big boat anchor soon.
Get it to another dealer as soon as you can.
CMOS
Some shavings may not necessarily be abnormal, especially if it was never checked for a long time; however, more often than not, this signals trouble. If you have lots of warranty left, just wipe the plug clean a few times to see if it the shavings get replenished and/or the noise is getting worse. If you have not much time left, insists on it being fixed.
CMOS
CMOS
a few small shaving in a diff = ok
a decent amount of shavings + whirling noise + 8.8" rear end = backed off pinion nut + trashed pinion bearing = bad
find a different dealer and don't let them BS you.
if you have your explorer shut off, chalk your wheels, put the tranny in neutral, and crawl under and rotate & move your rear driveshaft back and forth, I think you will find some play. it should have no play at all (or at least hardly any at all).
The size of the chunks are the size of a broken off pencil lead. Small in size but when comparing them to the shavings, they are large and stand out. The whinning is loudest from 0 to about 30 but I can still faintly hear it at faster speeds.
thank's for the help
No way is that normal. I'd bet money you're looking at a new ring and pinion set.
CMOS
CMOS
CMOS
Originally Posted by The SnoMan
The two "problems" are unreleated. When ring gears wear out they produce fleck or metal not shavings. Also failing bearings can do the same but "chucks or metal are usually left over from manufacturing or possible badly worn spider gearsfrom excessive wheel spinning and LSD diffs that are clutch based can also put some shavings or chucks in the lube too at times. He might also have a bearing problem in rear axle but it is hard to say for sure without hearing or know the true nature of the noise. Worn ring gears tend to get noisier with speed, not quieter.
Every rear i've had that started making noise ended badly, whether it being a destroyed pinion bearing or ground up spider gears, the chunk will destroy something.
Also, manufacturing normally don't leave chunks laying around in your diff. When they do, bad things similar to this happen.
LSD clutch packs contain friction material. Friction material can have metal in it, but it is normally tiny pieces that wouldn't cause trouble.
-chrono-
more than likely, the whining is improper mesh between the gears, like said, gonna need all gone threw with new bearings, as there gonna be pretty shot from all the shavings
very true. And most times the improper mesh is caused by a failing bearing which misaligns the pinion or carrier enough to foobar everything. However, I am guessing the whining is coming from the bearings. Gearsets, when properly setup don't whine.
This diff need to be looked over by a qualified dealer to be repaired. If the bearings are going bad, the more it is ran, the worse the destruction will be.
