Dumb ?: Which tank in which? Aux / main?
Main / Aux.
First -- Merry Christmas to all here at FTE.
My "78" F150 is marked on the switch, Main (lower position) Aux.(upper position) the Main tank is the side (midship) tank and the rear is the Aux.
When I first got the truck , I ran on the rear tank first, when it ran out of gas I switched to the front tank and it took about 5 miles before it finally started picking up enough fuel to run at highway speed. The reason for this is because the switchover valve is located right in front of thr rear tank. When switched over it had to pull fuel from the front tank back to the valve then up to the fuel pump.(stock mechanical fuel pump). If you run the Main (front ) tank dry then switch to the Aux.( rear ) tank the fuel is only a few inches from the valve and there is no lag. ( apparently when running on the rear tank the fuel in the line from the front tank drains back into the front tank). I had this happen twice before I realized I have to run the front (main ) tank first. Hope this helps. Tyqmonn aka Posford aka Nick Sr..
The following users liked this post:
the 6 shop manuals and part breakdowns all list the inbetween rear rail tank as the main. ford even calls the saddle tank aux, my build sheet says aux saddle tank. all the trucks that did not have the aux from factory still had the rear tank, so that is the main tank. the saddle was extra. i have the ford truck buyers guide for 73 and 78 it lists a side saddle tank as optional.
the thing is it is really easy to screw the system up. on the selector valve there is 3 hoses one goes to the fuel pump one is main the other is aux. when people replace the hoses they sometimes get put on the wrong port. so you could turn the aux into the main by just flipping the hoses
Hi, again I believe both of my trucks to be original.On page 9 of the original owners manuel my Lariat came with (brown book 1978 0wners manuel for f100 thru f350 series printed NOV 1977 2nd printing part # d8TA-19A32-BD) It states
The fuel valve is energized when the fuel selector switch is moved from MAIN to AUX position,allowing fuel flow from the auxiliary tank.On vehicles equipped with duel fuel tanks,the ""MAIN"" position supplies fuel to the engine from the midship fuel tank.
It also provides a diagram AUX up Main down for switch
I agree conventional wisdom would say that since all our trucks of that era had at least the rear tank and the front or mid-ship tank was a option that the rear would be considered the main tank.That however is not the case.As stated above by the manuel the rear tank in a dual setup is called the AUX and the mid ship is considered the Main. nuff said and Happy Holidays
Hi Milion,Just so I understand you.Are you saying that the owners manuel is wrong.I don't know how you interpet the diagram.I look at it like this way.1st off the rear tank is labeled standard (not main) in the diagram and I think we all agree that that back tank was standard on all our trucks.2nd I think in that particular diagram they use the word auxillary when a better word would of been optional.I also think we agree that the mid ship tank was a factory option.So (with no disrespect) I think because when the diagram was written the powers that be used the word auxillary when they should of used a more appropriate word like optional. Some folks in here think the diagram and the way the engineers set up or labeled the switch or governed how it worked is connected.I don't however.I believe the owners manuel not a misworded diagram.I can scan and email anyone who want's to see what the manuel says(earlier post)Regads to all 78
