Dumb ?: Which tank in which? Aux / main? - Page 2 - Ford Truck Enthusiasts Forums
Old 12-24-2005, 07:14 PM
Mr. Fixit
Mr. Fixit is offline
Mr. Fixit is starting off with a positive reputation.
Was once told the larger tank is set up as the main tank on these trucks but I doubt it. Probably has to do more with the influence of the ghost of Henry Ford. Apparently he is still pissed off that these trucks came in colors other than black - so it may be a random setup!
Old 12-24-2005, 07:50 PM
Tyqmonn's Avatar
Tyqmonn
Tyqmonn is offline
Tyqmonn is starting off with a positive reputation.
Main / Aux.
First -- Merry Christmas to all here at FTE.
My "78" F150 is marked on the switch, Main (lower position) Aux.(upper position) the Main tank is the side (midship) tank and the rear is the Aux.
When I first got the truck , I ran on the rear tank first, when it ran out of gas I switched to the front tank and it took about 5 miles before it finally started picking up enough fuel to run at highway speed. The reason for this is because the switchover valve is located right in front of thr rear tank. When switched over it had to pull fuel from the front tank back to the valve then up to the fuel pump.(stock mechanical fuel pump). If you run the Main (front ) tank dry then switch to the Aux.( rear ) tank the fuel is only a few inches from the valve and there is no lag. ( apparently when running on the rear tank the fuel in the line from the front tank drains back into the front tank). I had this happen twice before I realized I have to run the front (main ) tank first. Hope this helps. Tyqmonn aka Posford aka Nick Sr..
Old 12-24-2005, 07:52 PM
Mil1ion
Mil1ion is offline
Mil1ion is starting off with a positive reputation.
The Truth is:
The REAR Tank on those years trucks that did not have an in-cab tank (ie: 1978).... is considered the MAIN Tank.
The side or saddle tank FRONT is considered the Auxilliary Tank
Old 12-24-2005, 08:24 PM
Tyqmonn's Avatar
Tyqmonn
Tyqmonn is offline
Tanks
I have to disagree with you Mil1ion, in the 78 F150 the front (side ) tank is the MAIN & the rear tank is the AUX. Nothing on my truck has been changed and that's the way it is.
Old 12-24-2005, 08:33 PM
ford390gashog's Avatar
ford390gashog
ford390gashog is online now
ford390gashog has much to be proud offord390gashog has much to be proud offord390gashog has much to be proud offord390gashog has much to be proud offord390gashog has much to be proud offord390gashog has much to be proud offord390gashog has much to be proud offord390gashog has much to be proud offord390gashog has much to be proud of
the 6 shop manuals and part breakdowns all list the inbetween rear rail tank as the main. ford even calls the saddle tank aux, my build sheet says aux saddle tank. all the trucks that did not have the aux from factory still had the rear tank, so that is the main tank. the saddle was extra. i have the ford truck buyers guide for 73 and 78 it lists a side saddle tank as optional.
the thing is it is really easy to screw the system up. on the selector valve there is 3 hoses one goes to the fuel pump one is main the other is aux. when people replace the hoses they sometimes get put on the wrong port. so you could turn the aux into the main by just flipping the hoses
Old 12-24-2005, 08:50 PM
Mil1ion
Mil1ion is offline
Ty,No offence at all.
You can agrue all you want.
I go by Ford's explanation not hearsay.
The position of the switch means nothing.
It is a physical Attribute. The Main tank goes near the rear axle.
The Side AUX tank is an add-on .
Old 12-24-2005, 08:51 PM
X36
X36 is offline
X36 is starting off with a positive reputation.
Hi, again I believe both of my trucks to be original.On page 9 of the original owners manuel my Lariat came with (brown book 1978 0wners manuel for f100 thru f350 series printed NOV 1977 2nd printing part # d8TA-19A32-BD) It states
The fuel valve is energized when the fuel selector switch is moved from MAIN to AUX position,allowing fuel flow from the auxiliary tank.On vehicles equipped with duel fuel tanks,the ""MAIN"" position supplies fuel to the engine from the midship fuel tank.
It also provides a diagram AUX up Main down for switch
I agree conventional wisdom would say that since all our trucks of that era had at least the rear tank and the front or mid-ship tank was a option that the rear would be considered the main tank.That however is not the case.As stated above by the manuel the rear tank in a dual setup is called the AUX and the mid ship is considered the Main. nuff said and Happy Holidays
Old 12-24-2005, 08:52 PM
ford390gashog
look at it like this no rear tank no way to secure the spare tire,so it is the main.
Old 12-24-2005, 08:53 PM
Mil1ion
Mil1ion is offline
I edited my previous reply
Old 12-24-2005, 09:00 PM
ford390gashog
thats the same diagram i have. thanks
Old 12-24-2005, 09:51 PM
X36
X36 is offline
Hi Milion,Just so I understand you.Are you saying that the owners manuel is wrong.I don't know how you interpet the diagram.I look at it like this way.1st off the rear tank is labeled standard (not main) in the diagram and I think we all agree that that back tank was standard on all our trucks.2nd I think in that particular diagram they use the word auxillary when a better word would of been optional.I also think we agree that the mid ship tank was a factory option.So (with no disrespect) I think because when the diagram was written the powers that be used the word auxillary when they should of used a more appropriate word like optional. Some folks in here think the diagram and the way the engineers set up or labeled the switch or governed how it worked is connected.I don't however.I believe the owners manuel not a misworded diagram.I can scan and email anyone who want's to see what the manuel says(earlier post)Regads to all 78
Old 12-24-2005, 09:58 PM
Matts72's Avatar
Matts72
Matts72 is offline
Matts72 has a good reputation on FTE.Matts72 has a good reputation on FTE.Matts72 has a good reputation on FTE.
78f250supercab...(and others )
The midship tank refers to the tank between the frame rails in the rear... kinda confusing... the auxilliary is on the side... This is how my 79 is.
  #28
Old 12-24-2005, 10:51 PM
77bigblock's Avatar
77bigblock
77bigblock is offline
77bigblock is starting off with a positive reputation.
For what it's worth, On my 77, my cab tank is the main, rear is the auxilary. It could be all goofed up, I don't know. I'm just happy that they both work.
Wouldn't the guage be all messed up if the tanks were plumbed into the selector valve wrong? Just a thought.
  #29
Old 12-24-2005, 11:16 PM
79Indy's Avatar
79Indy
79Indy is offline
79Indy is starting off with a positive reputation.
I guess I'm glad mine just says Front/Rear. No confusion there.
  #30
Old 12-24-2005, 11:45 PM
Vinford's Avatar
Vinford
Vinford is offline
Vinford has a good reputation on FTE.Vinford has a good reputation on FTE.
On 78 and 79's the rear tank is the main and the side tank is the aux.
Maybe diffrent on 77's and before!
Quick Reply: Dumb ?: Which tank in which? Aux / main?
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
