Over Drive light
Old Dec 23, 2005 | 01:20 PM
cito's Avatar
cito
Over Drive light
I have a Expy 97 eb 4x4, and the light of the over drive start blinking and the tramsmision is shifting hard, did someone have an idea what can I do?
Old Dec 23, 2005 | 04:14 PM
'93 SVT's Avatar
'93 SVT
do a search on VSS... "vehicle speed sensor" you may get lucky and have this $26 part (at NAPA) failing you. if not, you're going to have to take it to auto zone (scans codes for free), a tranny shop (scans for $0-$75), or the stealership (scans for $75+). normally an indication of the VSS malfunctioning is the speedometer not working properly in addition to the flashing OD light and rough shifts. my '97 2wd's tranny went at 150k and it had the same symptoms as yours. i tried the VSS, but unfortunately my was problem was much larger than that.... $650 for a used 20k tranny out of the junkyard. install was not fun but i did it. truck runs flawlessly now.
Old Dec 23, 2005 | 07:15 PM
98expeditionXLT's Avatar
98expeditionXLT
I had the blinking overdrive off condition once when I drove on a very hilly highway for about 60 miles. My transmission was constantly shifting in and out of overdrive. About 10 miles before my destination I got the blinking condition and noticed that the transmission was shifting rough. When I got to my destination I shut off the Expy and two hours later upon our departure everything was fine again. On the way home on the same stetch of road, I kept the overdrive off. This happened about 2.5 years ago and I have not had a problem since with the exception of a broken modulator spring in the transmission.
Old Dec 29, 2005 | 06:16 AM
cito's Avatar
cito
Thanks guys for your help. I went to a Transmision Expert and he determine was the converter clutch. Change the Converter Clutch and problem resolve, I feel the shifting so smoth and confortable. Thanks again.
frod32w
Nov 9, 2014 08:59 AM
powerstroke79
Jan 31, 2014 01:11 AM
remmers
21
Nov 9, 2009 07:42 AM
SHILO
Aug 8, 2009 11:01 PM
